![]() | Home > Technical > Washer motor upgrade? |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Do you have a rear wash wipe? If your 110 is a DC then you could have one motor for each side of the screen! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
Nah, station wagon so the rear pump is in use.
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
I've been thinking along the same lines i.e. additional washer nozzle and more powerful washer pump. I also considered using different washer nozzles with a spray/ mist / fan shaped pattern for greater washing efficiency but drew a blank on that. I am told that a better pump can be probably be fitted but haven't got any further on that yet. I believe that a headlamp washer pump might be more powerful - the risk is, of course, that if it's too powerful it blows the system apart at some joint along the route from reservoir to nozzle.
Do you have any pictures of your twin nozzle set up? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
could you mount some VW / Audi ones in the bonnet like a normal car? 2002 90 Td5 Station Wagon
Possibly but it would mean cutting holes in the bonnet so you would want to be damn sure that it was going to work first.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
But at least you'd be able to recognise your bonnet when it turns up on ebay!
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
..... an't get it off can they Defender4.....we've covered the hinges in Wurthers wrappers.. ![]() ![]() |
Spot on!
