Home > Technical > Traction control |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Try taking off rapidly with your nearside wheels on a grass verge and your offside wheels on tarmac.
28th Sep 2012 10:41am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
I remember being told by an LRE instructor a while ago that the ABS / Traction Control on a Defender is 2-channel, rather than 4-channel as on a Disco or RR, which means that it only acts on the front wheels, not the back. No idea whether this is correct or not! I think one of the selling points of the 2012 2.2's in the brochures was a change to 4-channel ABS and TC, acting on all 4 wheels. But I could be wrong about that too! Just things dragged up from the memory banks. 2005 Td5 | 90 Station Wagon | Tonga Green
28th Sep 2012 10:59am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
That's interesting
28th Sep 2012 11:09am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
pumas have 4 channel abs t/c .
then they improved the system in 2011 |
28th Sep 2012 11:29am |
OK so even though it was one of the rear wheels spinning the TC should have cut in.
28th Sep 2012 11:40am |
depends or the amount of movement in comparison to the rest.
so if you were moving of and a wheel span a little then no probably not. It got a different system in 2011 MY. does the abs work? |
28th Sep 2012 11:44am |
OK this is what happened. Lights changed to green and I was turning right, because of the way the junction is I could not see up the road to the right where I want to travel. I pulled away in 1st and change to 2nd, then I start to turn right and now can see up the road. Coming down the hill at a hell of a rate is a saxo/pug or something driven by a young person. You know the type wide wheels, lowered and big exhaust, whole car worth about £2.50. He has not noticed the light are red for him and slams on the anchors! He is skidding towards me so I floor it and turn right at the same time the rear off side wheel is spinning on the damp road and making a noise like a episode of Starsky & Hutch. The wheel was spinning for about two to three meters. As I pull straight and drove up the road.
28th Sep 2012 12:05pm |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
If you want to do a simple test, jack a wheel up off the ground, turn the ignition on, (you don't need to start the car), and spin the wheel. The ABS/TC should activate the brake on that wheel.
Cheers, Tim |
28th Sep 2012 12:16pm |
Great!!! Thanks Tim
28th Sep 2012 12:19pm |
