Home > Puma (Tdci) > should I be seriously concerned ?
Caterham
as I'm sure many of you will be aware there's a spare live feed in the rear o/s rear wheel arch that many have used for an aux outlet in the rear.
my concern is that the electrical connector that is on the loom has fallen off due to the copper corroding thro Shocked
LR kindly crimped a new one on......and hey presto the same thing has happened again !!
I didn't think copper corroded ?
- so what causing it
- should I be concerned about the rest of the wiring loom?
Big Cry
Post #171484 28th Sep 2012 9:00am
K9F
If it's still a live feed and dampness is getting in the wiring the corrosion can and will track back under the insulation. Electrically iosolate the feed, cut the connector off and cap the end of the cables with heatshrink or tape and seal them up enough to stop water ingress would be my advice. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #171493 28th Sep 2012 9:08am
Happyoldgit
Are you referring the the spare feed behind the speaker panel, if so perhaps you've got a water leak behind there. If the rest of the loom and connectors in that area look ok I would just cut back and re-crimp some new terminals on there and then cover them in silicone grease or petroleum jelly. Steve.
http://forums.lr4x4.com
Post #171494 28th Sep 2012 9:09am
Caterham
not sure if its different on a 90 - but would imagine all the 110's are the same.
in which case surely everyone else's spare connector (behind the speaker panel) will also be getting wet (water from wheel arch when out in the rain) but probably haven't fallen off ?
I'm sure there's plenty of other connectors that get wet (can't think of any at the moment) yet haven't fallen off?
plus would you expect it to corrode / rot through in 9 months ?
Post #171506 28th Sep 2012 9:32am
ickle
The connector on mine is behind the speaker panel, above the wheel arch - inside the car and away from the road salt / spray - is yours under the wheel arch?
Post #171660 28th Sep 2012 8:49pm
SGH
My 130 has that connector open to the elements on nearside on top of rear crossmember Shocked 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #171663 28th Sep 2012 8:53pm
Caterham
ickle - i have to crook my neck but yes the connector is visable inside the wheel arch.
sgh - yours is exposed to the elements but i bet it hasn't corroded and fallen off? - so how come mine has?
Post #171678 28th Sep 2012 9:16pm
SGH
Mines only 6 months old and yet to hit the 2000 mile barrier Rolling with laughter 993 Varioram - Guards Red
Post #171679 28th Sep 2012 9:18pm
Caterham
mine was only about 6 months old the first time it fell off
perhaps done a few more miles tho !
Post #171681 28th Sep 2012 9:21pm
SGH
TBH mine is not had hardly any wet weather driving. I want to Dinatrol it soon and have tried to keep it clean but will heat shrink the connector to prevent corrosion. 993 Varioram - Guards Red
Post #171683 28th Sep 2012 9:26pm
