![]() | Home > Puma (Tdci) > EGR Valve Cleaning! |
Just checked the eBay ones - presumably I could buy a few solid ones and drill my own holes...
The ones with mounting hooks (open holes) are presumably meant to slip in between a gap without having to undo the bolts entirely. Does that make sense? I'll go ![]() But shout it at them in German because life is also terrifying and confusing... |
Just bought this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0697422591 Either the hole will be a bit too big (I'll never know) or too small (I'll make it bigger). I'll report how I get on ![]() But shout it at them in German because life is also terrifying and confusing... |
Sorry - forgot to say "ta" to Mal and Steve
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Your welcome. Although Mal has given the more useful info I've just been confusing people as always
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Ze, Steve,
No worries....I am running on a 12mm blank and have been for some 2 years 3 months. I do occasionally (when the weather is cold only in the Winter months) get a MIL light with associated P1103 code maybe once a month. I have not had any EGR related faults since whereas I endured a fair few previous. Undoubtedly since then there have been further developments in the EGR blanking scene and I am unsure where exactly we stand now? The first on the scene with a solution I believe was BAS with an ECU 'switch off' procedure which as stated I didn't have a BAS map. The basic blanking with an orifice for me is a well-proven, economy improving and trouble-free modification that I carried out before warranty expiry and one I would carry out again in the event of nothing more convenient being available. I also didn't like the idea of blanking off the EGR valve completely and running with a permanent MIL light as this could in my view mask a more serious problem should one have arose. I do wonder if any of the other individuals who purchased the original blanks are still running with them? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Quick question - is there a bit of movement between the EGR flange/exhaust manifold when the nuts are undone, or will I have to remove the exhaust manifold entirely? I only need a cm or so to slip the plate in. Also - did you take precautions against a leaky join when reassembling? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Matt
There is loads of room to insert the plate and you do not have to use a sealant. I don't use the plates any longer but when I did I changed it quite a few times without any issues Boy |
Brilliant - thanks
Bear in mind also that all the EGR bolts have a torque setting to be tightened to ideally so if you have a torque wrench they are:
10 NM (7lb.ft) for the M6 bolts 23 NM (17lb.ft) for the M8 bolts ![]() β½οΈπ’οΈβοΈπ§°πͺ |
![]() Hence my question about how much "give" when the nuts are undone... Hope I'm not being too optimistic. The EGR itself is a ![]() ![]() Thanks for the reminder - I killed my small torquer on the Audi ![]() But shout it at them in German because life is also terrifying and confusing... |
You shouldn't have too much trouble with it. I will be replacing mine completely all being well end of this week coming. As regards getting to it. It is difficult yes but what I'd do is wear a pair of disposable gloves that way it will at least protect the back of your hands a bit from scrapes and scratches (Even if it does tare them up) Also far easier to do with a socket set than with spanners I'd have thought due to the tight access.
Good luck ![]() β½οΈπ’οΈβοΈπ§°πͺ |
![]() I thought you can just loosen the two stud nuts on the exhaust manifold/EGR pickup at the rear of the engine and slip the plate in. Mal - HELP ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Top Tip....
Left hand side of engine, locate EGR Valve manifold branch and remove the two M8 bolts retaining gasket! At this juncture remove the studs and replace with two bolts M8 bolts it makes future swap outs so much easier and less time consuming. ![]() Originally two M8 bolts for this very purpose were supplied with the blanking plates..... ![]() Treat every day as if it is your last....one day you will be right!! |
Deleted due to stupidity... again
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
