Home > Td5 > Disco 2 transfer box - where to buy |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
These guys - every time:
http://www.ashcroft-transmissions.co.uk/ And more specifically, transfer boxes here http://www.ashcroft-transmissions.co.uk/in...mp;catId=5 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
26th Sep 2012 11:00am |
MPN Member Since: 23 Sep 2012 Location: Tuusula Posts: 18 |
Great!
Many thanks Martin! |
26th Sep 2012 11:21am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
you can either get the D2 Q Q for quiet gear set and fit them into your TB or get a TB from a 300 tdi discovery that has centre diff lock
26th Sep 2012 11:37am |
Did I get this right...
Two ways to do this. 1) Fitting gears of D2 box to my existing box 2) Switch to a 300tdi disco box ...right? |
26th Sep 2012 11:46am |
This page http://www.ashcroft-transmissions.co.uk/in...p;catId=70
and this one http://www.ashcroft-transmissions.co.uk/in...oductId=44 Tells you about raising the gearing to make the Defender (pre Puma) better on roads by raisin the gearing... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
26th Sep 2012 12:03pm |
Ah!!
So I can buy those gears only! That would be great. Thanks for your replies guys. I know nothing of this stuff, but try to learn. Considering this is my third Defender, I should be ashamed. |
26th Sep 2012 12:08pm |
ashcrofts stock the Q gears aswell as refurbished TBoxes etc. if you can rebuild it locally the gears will be the cheapest option. |
26th Sep 2012 12:31pm |
Hands down the best way to do this (considering logistics as well). Thanks heaps! |
26th Sep 2012 12:33pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 |
Ashcroft Q gear set - made a large difference in noise and cruising speeds
26th Sep 2012 1:48pm |
