Home > Td5 > Disco 2 transfer box - where to buy
MPN
Finland 2003 Defender 110 Td5 USW Belize Green
I'm seriously considering swapping the transfer box on my 110.
As usual, part availability is VERY poor in Finland, and when found, prices are steep.
So, where would one go and buy D2 box needed for this conversion in UK?
Conditioned and new are of interest.
Cheers,
M
Post #170976 26th Sep 2012 10:59am
MartinK
These guys - every time:
http://www.ashcroft-transmissions.co.uk/
And more specifically, transfer boxes here
http://www.ashcroft-transmissions.co.uk/in...mp;catId=5 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #170977 26th Sep 2012 11:00am
MPN
Great!
Many thanks Martin! Bow down
Post #170983 26th Sep 2012 11:21am
T1G UP
you can either get the D2 Q Q for quiet gear set and fit them into your TB or get a TB from a 300 tdi discovery that has centre diff lock
Post #170986 26th Sep 2012 11:37am
MPN
Did I get this right...
Two ways to do this.
1) Fitting gears of D2 box to my existing box
2) Switch to a 300tdi disco box
...right? Embarassed
Post #170989 26th Sep 2012 11:46am
MartinK
This page http://www.ashcroft-transmissions.co.uk/in...p;catId=70
and this one http://www.ashcroft-transmissions.co.uk/in...oductId=44
Tells you about raising the gearing to make the Defender (pre Puma) better on roads by raisin the gearing... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #170993 26th Sep 2012 12:03pm
MPN
Ah!!
So I can buy those gears only!
That would be great.
Thanks for your replies guys. I know nothing of this stuff, but try to learn.
Considering this is my third Defender, I should be ashamed. Embarassed
Post #170995 26th Sep 2012 12:08pm
T1G UP
MPN wrote:
Ah!!
ashcrofts stock the Q gears aswell as refurbished TBoxes etc. if you can rebuild it locally the gears will be the cheapest option.
Post #170999 26th Sep 2012 12:31pm
MPN
Thumbs Up
Hands down the best way to do this (considering logistics as well).
Thanks heaps!
Post #171000 26th Sep 2012 12:33pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Ashcroft Q gear set - made a large difference in noise and cruising speeds Very Happy
Post #171006 26th Sep 2012 1:48pm
