Home > Puma (Tdci) > Reversing light switch
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi all!
Does anyone know the part number for the reverse light switch on a 2010 Puma?
Mine is very intermittant, and I may as well replace it while I have the old one out.
thanks in advance,
Paul. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #170591 24th Sep 2012 9:31pm
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1986wt_982
Thumbs Up
Be sure to take some picture of the switch ect if you can I have had the same issue myself.
Steve
Post #170597 24th Sep 2012 9:48pm
Shax
custom90steve wrote:
http://www.ebay.co.uk/itm/LAND-ROVER-DEFENDER-PUMA-Reverse-Light-Switch-07-LR005160-/370632377675#ht_1986wt_982
Thumbs Up
Steve
Ta for the linky...
I popped the p/no (LR005160) from the ebay listing into Google, and this came up :
http://www.brit-car.co.uk/product.php?xProd=151127
Looks like a completely different switch!!
Which one is the correct one to get? ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #170599 24th Sep 2012 9:56pm
Indeed it does. Personally I think they both do the same job only different colour. Personally I'd go for your link because the (G) in part of the title indicates a Genuine part. The E-bay version one has a few fish 'small print' details at the bottom. Another thread may be of use to you: http://www.defender2.net/forum/topic3724.html
If you don't want to risk it just give the dealers a ring with the PN and you will be certain to get a genuine and correct part.
Post #170603 24th Sep 2012 10:11pm
I had exactly the same problem (intermittency) with my '07 Puma and it turned out that the switch simply wasn't screwed fully into the gearbox. I bought a new switch before finding this out, of course, but the old one was less than finger-tight and once properly screwed in I have had no further problems.
It is very inaccessible on the Puma, but you can get to it if you take the access panel under the cubby (between the front seats) out. I did post a 'how-to' here
Post #170730 25th Sep 2012 12:11pm
I remember that Blackwolf. And very helpful it was too. Thumbs Up Mine is now working reliably but have an even more odd problem with it. An LED bulb works perfectly but the correct filament bulb won't work at all in my reverse light. Checked and checked it and still the same outcome. So I simply use the LED now but I can't work it out Confused
Post #170735 25th Sep 2012 12:26pm
