Home > Puma (Tdci) > Reversing light switch |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20378 |
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1986wt_982
Be sure to take some picture of the switch ect if you can I have had the same issue myself. Steve $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Sep 2012 9:48pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Ta for the linky... I popped the p/no (LR005160) from the ebay listing into Google, and this came up : http://www.brit-car.co.uk/product.php?xProd=151127 Looks like a completely different switch!! Which one is the correct one to get? ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
24th Sep 2012 9:56pm |
Indeed it does. Personally I think they both do the same job only different colour. Personally I'd go for your link because the (G) in part of the title indicates a Genuine part. The E-bay version one has a few fish 'small print' details at the bottom. Another thread may be of use to you: http://www.defender2.net/forum/topic3724.html
If you don't want to risk it just give the dealers a ring with the PN and you will be certain to get a genuine and correct part. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Sep 2012 10:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
I had exactly the same problem (intermittency) with my '07 Puma and it turned out that the switch simply wasn't screwed fully into the gearbox. I bought a new switch before finding this out, of course, but the old one was less than finger-tight and once properly screwed in I have had no further problems.
It is very inaccessible on the Puma, but you can get to it if you take the access panel under the cubby (between the front seats) out. I did post a 'how-to' here |
25th Sep 2012 12:11pm |
I remember that Blackwolf. And very helpful it was too. Mine is now working reliably but have an even more odd problem with it. An LED bulb works perfectly but the correct filament bulb won't work at all in my reverse light. Checked and checked it and still the same outcome. So I simply use the LED now but I can't work it out $W33T $0U7H3RN $UG4R
25th Sep 2012 12:26pm |
