Home > Puma (Tdci) > fuel tank breather relocation. |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 |
Hi all. I've just unclipped my breather from it's location under the wheel arch and shoved it behind the light cover. Do I have to fasten it to anything behind there or is it o.k just hanging about. Cheers,
Richard 1963 Series 2A truck cab 2008 110 SW |
22nd Oct 2009 12:04pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
Why not add an extension and run it along the chassis rail then up to the bulk head. That is what I did to mine. 1982 88" 2.25 diesel
22nd Oct 2009 1:23pm |
Cheers for that Spud 1963 Series 2A truck cab
2008 110 SW |
22nd Oct 2009 4:29pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
You should be all right just tucking it under the plastic flap.
Obviously an extension is a better long-term solution but moving it is a good start. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
23rd Oct 2009 10:31am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I also extended mine into the cab where my dual battery wires come in and have had no fumes or ill effects, only peace of mind Puma 110 - gone
Series III 1973 - going strong |
24th Oct 2009 5:24am |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
hi Richard! which specific wheel arc is it located so i can relocate mine also... Thanks in advance |
24th Oct 2009 5:33am |
Richard[/quote]
hi Richard! which specific wheel arc is it located so i can relocate mine also... Thanks in advance[/quote] Hi. It's under the rear left wheel arch as you look at it from the back. Richard 1963 Series 2A truck cab 2008 110 SW |
24th Oct 2009 7:44am |
Yup, rear LHS. It looks like a 6mm tube that is bent over 180 deg with a 2" radius on the bend. At the back of the wheel arch. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
24th Oct 2009 8:21pm |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Mine being a 10MY had it on the drivers side (RHS) above the tank near the chassis rail: Click image to enlarge This I think was an attempt by LR to get it out of the spray from the rear wheel. Mine has been extended subequently during the course of the installation of a 40 litre auxiliary fuel tank behind the rear wheel to a higher position. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
24th Oct 2009 8:38pm |
3WHouse Member Since: 24 Jan 2008 Location: Msk Posts: 70 |
Lift upward..))
Click image to enlarge Def`s 90 & 110 Monochrome. You can go fast i can go anywhere.)) http://www.offroadpower.ru/ |
24th Oct 2009 8:54pm |
Thanks I found mine at the LHS.
25th Oct 2009 6:52am |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
love your pictures, does your club got out much Cheers Simon |
25th Oct 2009 6:00pm |
Extended mine along the chassis rail and up to the bulkhead over a year ago and everything has been fine. 1982 88" 2.25 diesel
29th Oct 2009 5:31pm |
] Also extended to the front bulkhead and no problems |
29th Oct 2009 6:15pm |
