Home > For Sale & Wanted > Interesting 130 3.9V8 for sale |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
This looks nice if you need the extra space.
http://www.carandclassic.co.uk/car/C333562 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
24th Sep 2012 9:40am |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Nice, but if its been fitted with those alloys which arent even strong enough for a 110 then what other bits are wrong?
24th Sep 2012 4:35pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
whats wrong with them? there standard fit on an early td5 |
24th Sep 2012 4:43pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
THey are standard fit on TD5 90s.
The weight rating of those wheels are 850Kg..... the rear loaded weight of a 110 is 1750Kg so if on the flat ground you will still be over its max working weight limit never mind if you have to go off road and put more weight on one wheel. So.... with that in mind, empty there is probably about 1 ton on the rear axle, add the passengers (say 8 in the back) at say 80Kg each 650Kg, and then personal kit at say 200Kg.... that is a rear axle weight of 1850Kg- I would say that is an accident waiting to happen!! Glyn |
24th Sep 2012 4:55pm |
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 |
If they are Genuine Land Rover Tornado/Freestyle alloys then they were standard fit on 90s only, and they are not weight rated for a 110 or 130. However, they could be the aftermarket Firestyle alloys which are weight rated for 110 and fit on drum braked rear axles, which could well be the case here as it was an MOD Rapier vehicle which (I think) were originally carb 3.5 V8 and pre-dated disk rears. Either way, I wouldn't fancy them on a 130. But then I think it's fairly hideous anyway. Fully Restored 89 110 CSW V8 CLS 350 CDI for the sensible stuff |
24th Sep 2012 5:04pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
Gak.
A normal 130 is a droolsome object. That one looks like someone's DT homework. |
24th Sep 2012 7:16pm |
Not exactly an insurmountable issue, some new wheels. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
24th Sep 2012 9:27pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
I love forums, after a conversation yesterday regarding wheels for my Sankey based camping trailer on PM I have been hunting for a max weight figure for Freestyles and without asking it appears!
Trailer MAM will be 1100kg so the axle weight will be erm.. 1100Kg which will give me a 600kg margin of safety to pay with. |
25th Sep 2012 6:35am |
