![]() | Home > Technical > Bit of a clunk |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Any of the suspension or shock absorber bushes, or drive flange worn??
Get a bar in a wiggle around the bushes and check for play, if all ok, drop off the front rubber cap and check for play between the flange and the half shaft, you may need to remove the circlip to see clearly. Keith |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
Thanks Keith, I will give it a bash, Keith Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
