Home > Technical > Battery switch and Automatic charging relay
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
I have Blue Sea Battery switch (1) - (2) - (1+2) - (Off) and Automatic Charging Relay. Will it work Ok if I connect ACR to contacts 1 and 2 of switch on scheme:
I'd like to use either battery1 or battery2 or both (for start engine, etc.), i.e. when batt1 in use batt2 is charging and when batt2 in use batt1 is charging. Will it work that way?
I understand that Switch is not nessesary, but I already have it Smile and want manual control.
Cheers Puma 110
Post #169731 21st Sep 2012 4:50pm
hi Denis
not sure if your system will work but there is another bluesea system that does exactly what you want. have a look on the mobilecentre website. it runs automatic charging, isolate or joins battery 1+2
Tim at Mobilecentre is really helpful
Post #169857 22nd Sep 2012 6:55am
Denis
Hi BPman,
Thanks, I've looked at BlueSea site - they have "add a battery" system - it is 3-position (On-Off-Combine) switch and ACR. But I'd like 4-position switch to use either of 2 batteries as a main(starter) and rest battery for winching/invertor applications only.
So I have to decide how to use components I have.
Cheers Puma 110
Post #170197 23rd Sep 2012 3:28pm
hi Denis
contact Tim at mobilecentre (sponsor) - he's a fountain of knowledge
Post #170281 23rd Sep 2012 6:33pm
Denis
Ok Thumbs Up pm to Tim sent Puma 110
Post #170292 23rd Sep 2012 6:52pm
mobilecentre
The ACR will combine when it senses engine running so you will not be able to isolate 1 & 2 unless you use an ACR with a switch which then involes more work. You could automate it but this would need more wiring again if I undertand you correctly.
Post #171113 26th Sep 2012 7:36pm
nikojo
Depending on the type of regulator/alternator you have..........be careful switching to "off" while the engine/alternator is operating. If this happens the alternator voltage spikes and this can damage the diodes (regulator) this "frying" your alternator.
You likely have an alternator with an internal regulator that would be immune to this but all the same.
Just dont' switch to "off" until your engine is "off".
Post #184230 12th Nov 2012 4:32am
nikojo
Post #184231 12th Nov 2012 4:33am
Denis
Thanks for your insight nikojo!
Meanwhile I decided that my scheme will work o'k Laughing
It is similar to this BlueSea explanation of how to use a switch with ACR
 Puma 110
Post #184329 12th Nov 2012 2:47pm
