Home > Tdi > what's up ?
what's up ?
abc
Post #169664 21st Sep 2012 10:09am
K9F
Take it for a run, if the expansion tank is still cold maybe you've got an airlock. Have you had any major disturbance with the cooling system of late? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #169665 21st Sep 2012 10:11am
Laurie
Mud in the radiator?
Post #169669 21st Sep 2012 10:34am
thanks.
not mud in rad - it's been pressure washed
no signs of water leaks
not over heating .. just getting hotter than usual
rad is warm - so probably thermostat working .. maybe not opening enough ?
i need to run the engine and look to see if water moving in header tank ?
Post #169671 21st Sep 2012 10:52am
Sounds very much like the water isn't being circulated, so pump would be my guess. I've seen a couple of pumps where the vanes have corroded away to the extent that they just don't push the water around anymore. Darren
Post #169672 21st Sep 2012 10:58am
@LRA - thats my thought at the moment, I will check to see if the water is moving in the pipes and heater tank
also - check for air locks
Post #169675 21st Sep 2012 11:23am
Laurie
Does the heater work?
That would show circulation.
Post #169676 21st Sep 2012 11:29am
cde
Post #169770 21st Sep 2012 7:08pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
before you strip out the thermostat it would be worth checking for an air lock. if i recall bleed radiator top plug first and then the plug on top of the thermostat housing. BM52
Post #169771 21st Sep 2012 7:13pm
good call bm52 - yes I will try that first, so is that the brass plug next to the thermostat or the plug ontop of the radiator (probably the plug ontop of the radiator) Thumbs Up
Post #169778 21st Sep 2012 7:22pm
bm52
from the workshop manual..
1. Remove plastic plugs from thermostat housing
and radiator.
2. Fill cooling system with 50% - 50% of
water/anti-freeze mixture.
3. Fill from expansion tank until radiator is full, with
level in expansion tank the same as in radiator.
NOTE: Care should be taken to avoid
excess coolant spillage from radiator.
4. Fit plastic plug in radiator.
5. Add a further 1 litre (1.76 pints) of coolant to
expansion tank and allow to settle.
6. Refit expansion tank cap and thermostat
housing plug.
7. Run engine at idle speed for five minutes.
8. Switch off engine, check that expansion tank
coolant is level with top of indicator post and top
up as necessary. BM52
Post #169809 21st Sep 2012 9:07pm
bm - thanks for the list, I ran thru the procedure and the engine is normal however the expansion tank is still cool / cold, been on a 5 mile run and temp stays in middle. maybe it was an airlock. certainly going to keep a close eye on it.
I think because its not used much the thermostat was stuck closed ? I took the brass plug out of the radiator housing and squeezed the pipes and the fluid is moving when each hose is squeezed (so thermostat is open) and the coolant moves about in the expansion tank so it does not look like there are any blockages
taking her out on the plains tonight, so we'll see how she behaves Thumbs Up
Post #169918 22nd Sep 2012 11:21am
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Poor earth is my guess...... Try turning lights and heater
On, if gauge goes up then you have bad earth. Have fun be happy
Post #170208 23rd Sep 2012 4:10pm
thanks Tom
been out today and still fine and still the expansion tank is cold ... Confused
Post #170269 23rd Sep 2012 6:15pm
T1G UP
bpman wrote:
thanks Tom
pump and or stat...the two things that affect cooling, circulation
Post #170317 23rd Sep 2012 8:05pm
