Home > Tdi > what's up ?
Page 2 of 2 <12
Been to the Land Rover doctors today, there was signs of water on the block from behind the P gasket so it had a new water pump, P Gasket and Thermostat and a transfusion ... still has an airlock.
The plug at the top of the radiator is full, the plug next to the thermostat is full, garage recommended leaving the truck on the level with the expansion tank cap off overnight .. I'll have another look in the morning.
Post #183531 9th Nov 2012 8:33pm
this morning, I took it out for a run up the hill, temperature went just over 1/2 way and stayed there, stopped at the top of the hill and had a look under the bonnet. the bottom hose is hot, the top hose is cool, the expansion tank is warm.
tried the heater, works a treat, left it on and the temp dropped to 1/2 way (normal)
my theory now is I have a blocked radiator or blocked bottom hose - thoughts anyone ?
Post #183790 10th Nov 2012 7:02pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Steve
As you've replaced a few things already might pay to replace expansion tank cap, even a slight leak will affect the cooling system. Wouldn't have thought your rad is blocked internally. 2007 TD5 90 Hard Top
Post #183795 10th Nov 2012 7:19pm
thanks Nige, but it's not using water, just not cooling it enough.
any idea what the small black connector does that joins the small radiator hose, the small thermostat hose to the expansion tank ? is it a one-way valve or just a connector ?
Post #183810 10th Nov 2012 7:44pm
Landlord
One way valve, as fitted to vehicles with a later Webasto, or so I believe 2007 TD5 90 Hard Top
Post #183916 11th Nov 2012 2:20am
there not a webasto on the 300.
just read up about another 300 tdi with the same symptoms and it looks like the block may need flushing. the owner used central heating flushing liquid - I might give that a try
Post #183945 11th Nov 2012 9:58am
ran central heating cleaner thru the engine for 2 hours and use high pressure water to flush it all out, some stuff with the consistency of egg-white / snot came out.
refilled with water and a/f mix ... better.
then took out for a test drive, put lights on and gauge went up Shocked - cleaned earths on dash, better still. so all appears to be good now.
On advice from another forum, I am also going to put a new earth on the dash to the bulkhead.
.. thanks for all your help
.. 25th Nov is ON Thumbs Up
Post #186258 19th Nov 2012 9:46am
Page 2 of 2 <12
