Home > Td5 > Weaping bottom radiator hose |
pormpaul Member Since: 12 Sep 2012 Location: Tennant Creek Australia Posts: 7 |
Hey everyone.
Ive got a Bottom radiator hose which is weaping slightly on when under pressure where it meets the water pump. the hose appears to be in good condition otherwise. Replace the hose? Take off and clean up? Or other options. Cheers Paul |
23rd Sep 2012 12:17am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 |
Make sure the clamp is tight? 1999 Defender TD5 110
23rd Sep 2012 8:05am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Are you sure it is the hose and not the pump? There are several O-rings in there which can start leaking. It is often hard to trace except for taking it apart.
23rd Sep 2012 10:28am |
Hey thanks for responses,
How can check if its a blokage? I hope its not the waterpump (not sure if Ive got the skill to rebuild), it does not appear to be leaking from there. Ill order some hoses today and replace. thanks |
23rd Sep 2012 10:53pm |
23rd Sep 2012 11:06pm |
