Home > Td5 > Weaping bottom radiator hose
pormpaul
2002 Defender 110 Td5 SW Alpine White
Hey everyone.
Ive got a Bottom radiator hose which is weaping slightly on when under pressure where it meets the water pump. the hose appears to be in good condition otherwise. Replace the hose? Take off and clean up? Or other options.
Paul
Post #170082 23rd Sep 2012 12:17am
excossack
Make sure the clamp is tight? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #170100 23rd Sep 2012 8:05am
^ yes, is the hose clip tight enough ?
what condition is the radiator in ? (blockages?)
have you flushed the system ?
Post #170110 23rd Sep 2012 8:32am
wslr
Are you sure it is the hose and not the pump? There are several O-rings in there which can start leaking. It is often hard to trace except for taking it apart.
Post #170137 23rd Sep 2012 10:28am
pormpaul
Hey thanks for responses,
How can check if its a blokage? I hope its not the waterpump (not sure if Ive got the skill to rebuild), it does not appear to be leaking from there.
Ill order some hoses today and replace.
thanks
Post #170344 23rd Sep 2012 10:53pm
pormpaul
thanks
Post #170347 23rd Sep 2012 11:06pm
