Home > For Sale & Wanted > WTD TD5 15p engine (Now got one thanks)
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
I know items long shot but after a head failure I am going to replace my engine so I am after a replacement, I have a couple of options but just thought I would check if anyone had one FS.
Cheers, Jason.
Post #169733 21st Sep 2012 5:10pm
K9F
Low mileage but not sure if it's a 10 of 15p?
http://www.ebay.co.uk/itm/landrover-discov...3ccad239b2
Or totally reconditioned for a ton more?
http://www.ebay.co.uk/itm/Td5-engine-15p-T...25758417e5
56K with 12 months warranty?
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...2ec1e08453
If you're keeping the vehicle and for peace of mind I personally would lean towards the total recondition.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #169747 21st Sep 2012 5:49pm
jasong4110
Cheers, I had seen them but the recon one looks a bit suspect to me with its painted rocker cover, covered for the photo.
Not sure I would want the one thrown in the back of the lorry...
Equicar have a couple and I can see where they have come from, and how they ended their life's after all a engine running for 10 minutes upside down may look fine but won't be.
Jason
Post #169754 21st Sep 2012 6:23pm
K9F
Me neither but for £300 less and 15k miles more on the engine (on the third choice) you get one as mentioned with a 12 month warranty!
Or choice 2....You get a totally reconditioned one (no warranty mentioned) for a ton more?
The marketplace obviously requires close scrutiny as there doesn't appear to be much difference in price at times between a second hand engine with warranty and one that appears to be reconditioned with no warranty mention. I would ask a few questions to see exactly how good the warranty was and how it would stand up with regards a potential claim, if possible get it backed up in writing. If you're retaining the vehicle surely a good warrantied engine would be best suited even if you have to 'shell out' a little more?
Good luck in your quest! Let us know how you get on! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #169831 21st Sep 2012 10:50pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Good advice on checking the warranty.
Have you thought about just replacing the head? The rest of these engines are very reliable, I know the head replacement after fitting will probably cost as much as an eBay engine but you will be fitting a much better head which has had the known weak points improved ( thicker material around injectors ) What you want is a Spanish made AMC head. I went this route and it really is a nicely made casting.
You then know exactly what you have, you could just be buying another weak head as it seems to effect rather a lot of them.
Just thought it was worth a mention.
Steve
Post #169879 22nd Sep 2012 7:57am
jasong4110
I think that's the big issue most warranties are not worth the paper, plus they don't cover your time and effort of fitting, So you fit it change the filters oil, etc run it up and have an issue best case they say no problem just return it for a refund....
I have a lead on a promising sounding engine so will update when it's sorted and the deal is done.
Jason
Post #169891 22nd Sep 2012 8:47am
jasong4110
Steve
Steve,
That's my big problem, and one I have been mulling over since it happened, the cost of the AMC head is £1,250.00 then it's £150.00 for the gaskets bolts etc so we are at £1,400.00. Then I would have to do the job which I could either pay for or do it myself. To be honest it's not a job I fancy doing myself so it would be another £380 for fitting plus oil etc. so lets say £2k all in.
I have a couple of options for replacement engines which come in between £1,500.00 and £1,700.00 both <40k on them and both known good. My truck has done 100k and I suspect the clutch does not have a lot of life left in it so an engine out would be a chance to sort that. So again looking at the figures lets say £1,600.00 for the engine £380.00 for the clutch and flywheel £100 for filters, oil, fluids etc and I am at the £2.1k mark again, but have done my clutch I also have a spare td5 engine and bits which I should get £500 for bringing the cost down to £1,600.00.
If I then took £600 from the above for a clutch change then I am at £1k for an engine change.
OK I take the risk of it happening again but this seems to be around 100k they go so In theroy i have 60k of running which for me is about six years.
Not an easy choice...
Jason
Post #169899 22nd Sep 2012 9:26am
Caterham
please forgive my ignorance but would it be worth contacting Pete at BAS to see if there's anything coming up following a 3.2 ltr upgrade?
Post #169910 22nd Sep 2012 10:17am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Not if he only wants to spend 2 k or less Rolling Eyes
Post #169927 22nd Sep 2012 12:30pm
jasong4110
Well thanks to Marcus mentioning it to Ian at IRB that I was in need of a new engine and deal has been done and I now have a replacement engine. Smile
Just the small job of fitting it now!! I was reading the instructions last night and it seems fairly straight forward, empty the fluids, remove the rads, unplug the looms and fuel, unbolt from the gearbox/engine and lift out.... Simple!!
Jason.
Post #169930 22nd Sep 2012 1:00pm
Steve B
Great news, sounds like it's all under control Very Happy
Steve
Post #170030 22nd Sep 2012 8:06pm
jasong4110
Steve
I hope so as I started to strip the old engine out this afternoon! Sad
Post #170033 22nd Sep 2012 8:11pm
Don't forget to program your ECU with the new injector codes.
And you got a reply from Ian? Bluddy hell you're lucky!!!!!! Whistle Whistle
Post #170164 23rd Sep 2012 12:06pm
jasong4110
Will do Jim, I've borrowed a rovercom to sort out the codes.
Hopefully the rain will stop this year and I can get the job done.
Jason.
Post #170172 23rd Sep 2012 12:55pm
Steve B
Very Happy
Needs a P.A IRB do Laughing
Post #170181 23rd Sep 2012 1:52pm
