Home > Tdi > clutch master cylinder leaking
Rob
England 1993 Defender 90 200 Tdi HT Epsom Green
I have now replaced the clutch master cylinder twice, the current one is a genuine part one from Paddocks, made by TRW. the 1st one was a Delphi...the Censored thing has started to leak again, never bloody lasts!!!!! have I been putting the wrong clutch fluid in, synthetic DOT 4??? Confused Shocked any ideas?????? its seriously Censored me off now
Post #169313 19th Sep 2012 5:38pm
paulgrs2
United Kingdom 1988 Defender 110 200 Tdi PU Baltic Blue
dot 4 is right mate yeah. Have you reset the stop screw correctly and the push rod adjustment so that the rod runs straight through it's cycle.
140mm pedal to floor pedal height and 1.5mm clearence between pushrod and cylinder piston (approx 10mm at pedal).
Post #173228 4th Oct 2012 8:57pm
jst
does the car stop in a straight line? ie is there a resistance somewhere causing premature failure? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #173235 4th Oct 2012 9:21pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Is your clutch very heavy ? maybe if it is the master cylinder is having to work at pressures it was not designed to do. When i had a new clutch fitted to my old Turbo Diesel years ago the new clutch was much lighter.Just a thought. 2005 Td5 90 XS
Steve
Post #173243 4th Oct 2012 9:30pm
