![]() | Home > Technical > DIM DIP |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
Can anyone help me, I wish to disable the dim dip function on my 2008 puma defender.
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
they don't have dim dip since certain e.u laws.
Commercials do 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
i've not seen that - i stand corrected. is the loom there on all models?
So all I have to do is find the resistor and disconnect the wires then?
apparently so. i have one of the resistors, i was going to fit it to mine. why do you want to disconnect it?
I do not want to use dim dip.
I would prefer to have side lights only on certain occasions. |
looking in my ws manual the resistor is under bonnet rh inner fender
Thank you , I will try and find it when it stops raining.
OK problem is solved, just cut the brown wire with green trace at side of multiplug r/o brake servo.
no more dim dip ![]() |
![]() 1968 1/32 scale Britains 109 Pick up. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 ![]() ![]() ![]() |
You'll find that you could have just unplugged it from the resistor pack, save cutting the loom. I'd tape the end of the cable up too, as that'll have 12v on it when the lights are on... you don't want that flapping about under the bonnet ![]() |
Naturally the ends have been taped and sealed back into the loom. It was easiest to cut wire as i could not get to resistor. |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
AHA! I've often wondered about this! Think I'll give it a go myself with mine, always preferred the look of them with just the side lights on. Looks like it has a dodgy earth or something at the moment.
Cheers! |
