![]() | Home > Puma (Tdci) > Defender 07 XS diesel - gearbox and clutch conundrum |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2455 ![]() ![]() ![]() |
Seems there is air in the circuit.
search under "clutch" and you will find all info regarding all clutch issues since 2007. Since 2007 LR uprated to its 4th friction plate version. Puma 110" SW ............................................................. Earth first. Other planets later |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Does the engine rev up in-between gearshifts?
Dingo Member Since: 26 Dec 2011 Location: Exmoor Posts: 7 ![]() |
MK
OK, I'll do some more homework on this revised clutch. wslr Between changes the engine does not rev up unless my R foot tells it to. ![]() Though that leads to another observation, derived from running around in the snow and ice. If I take my foot off the accelerator quickly, the revs stay up for about 3/4 of a second, then drop. I'd assumed this was part of the emissions mapping, as LR Exeter told me they would not re-map to make the revs drop immediately. The vehicle has not been without problems under warranty: 2 computers, then a complete re-wire and new looms at 18k miles. But I've had LRs in the UK and Middle East for over 37 years, so properly addicted.... |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
I had a similar problem with a Nissan 200SX years ago that was similar.
After driving for about 50 miles, I had to stop and release the pressure of the clutch hydralics but unscrewing the bleed valve. It turned out to be a dodgy slave cylinder that when I released the clutch pedal, it wouldn't release the pressure, so each press of the pedal put extra pressure in the system. If left overnight, it would eventually release the pressure. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Try changing gear without using clutch, match the revs to speed that should indicate if the box is ok, then try changing gear without fully decompressing clutch peddle, and try putting it in gear then push your foot right to the floor on the clutch and see if it try's moving
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Can't really pass on much advice, but other than checking master, slave and fluid (don't think you mentioned clutch fluid flush through).
I would consider dropping an email or giving the guys at Ashcroft Transmissions a call and explain the symptoms- they were more than helpfull and can normally tell you exactly where the fault is from a simple discription. Glyn ![]() ![]() |
progress is being made. I'll fill in the details in due course. AShcroft transmission fluid is due next week, asa first stage.
