Home > Technical > Removing transfer lever on Puma |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
How do I go about removing the transfer lever on a Puma ?
21st Aug 2012 10:08am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6073 |
There was a similar thread on this a while back, SEARCH brings this one up....
21st Aug 2012 8:00pm |
No mention of removing the transfer lever though
21st Aug 2012 8:18pm |
You are a star Thank you
Great to meet you at Billing |
21st Aug 2012 8:37pm |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 |
If that doesn't make sense call me and I'll talk you through it 07714419998 any time
21st Aug 2012 8:42pm |
Saved Number to contacts if you wanted to delete from thread - Thanks very much for the offer, hugely appreciated
21st Aug 2012 8:46pm |
It's everywhere anyway |
21st Aug 2012 8:48pm |
Is replacement of the Transfer Lever as simple as this post implies?
I have just received an SVX one I purchased from a fellow forum member and was wondering if there is enough access from within the vehicle to disconnect/reconnect the linkages or does this have to be carried out underneath the vehicle where access is limited? As Go Beyond stated Diesel Jim's link is just for the Gear Lever not Transfer Lever. Any information would be gratefully received for any 'pitfalls' I may encounter before attempting the swap out? I could call the number above but my late dear-departed Mother always told me 'Not to talk to strangers.' Also if his phones are like mine I get enough cold callers as it is! I have also sent a 'pm' to Go Beyond. Thank you. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Sep 2012 7:20pm |
Mal, you have an email!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Sep 2012 9:59pm |
can't wait to see your xfer knob sunday Mal
13th Sep 2012 10:10pm |
Thanks Daniele.....
Lots on at the moment.....You can see my knob anytime!!! Probably still be in it's box though. Woodburner chimney/flue to sweep and new cowl to fit first. St Malo next week so probably won't get fitted this side of October. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Sep 2012 11:47pm |
Plenty of room and I have big hands.
14th Sep 2012 12:15am |
Reassuring, thank you. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Sep 2012 6:02am |
Hi Mal,
Thought I'd reply to your PM on here for the benefit of others. As you've probably worked out, I wanted to know how to remove the transfer lever so that we could cover it in leather, however I have discovered it's not necessary to remove any of the under floor gubbins as the standard lever can just be pulled off ! I suspect you could do the same with your SVX lever (if you wanted to) HTH Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
14th Sep 2012 9:03am |
