- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Grockle
![](templates/vbnew/images/spacer.gif)
shingwell wrote:Just wondered if anyone else has experienced this?
I have just had my front tyres replaced (at 22k miles) and the drivers side showed 5 or 6 patches of wear evenly spaced around the circumference - between the patches there was a fair amount of tread left, but at the worn spots it was non-existant (no I haven't been skidding!). The passenger side was far better but was just starting to show the same pattern. The tyre man said he had seen it before on Landies occasionally but didn't know what caused it.
They are the tyres fitted as standard on my '08 130 - Michelin XZL 7.50R16s I believe.
Also, I thought we were supposed to have progressed to tubeless these days but mine had tubes in, even though the tyres say tubeless on the sides!
Have you had the car from new,if not the front tyres could have been on the back with the diff lock engaged on the road causing uneven wear. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
17th Oct 2009 3:09pm |
AndrewS
Tubes in thats not correct. Who is your dealer? you should ask them whats going on.
17th Oct 2009 6:50pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
