Home > Puma (Tdci) > Battery is going to dead...
Eduardo
After 4 years and 7 months and more than 140,000 km, The start is going to be more dificult.
Before start inmediately and now took a little bit more.
So, I need to replace the battery.
Any idea of the requirements?
Amp per hour?
Max size?
Thanks in advance Eduardo
Post #167525 11th Sep 2012 4:25am
Sockpuppet
Seems to me like an like for like replacement would work well LR Genuine.
Post #167526 11th Sep 2012 5:22am
When I needed to replace the battery on my Disco 2 last year I decided after much pondering to go for a genuine LR replacement. The main reason being that the old one had done 9.1/2 years and 200,000 miles, which to me is a pretty good recommendation. It certainly outperformed any of the quality (Bosch etc) batteries I have had in the Series One.
So my suggestion would be if the genuine one worked for you up to now, stick with it.
Post #167545 11th Sep 2012 8:32am
Grockle
Hi Ed,
Hope your ok,I agree with the others fit a genuine battery Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #167555 11th Sep 2012 10:00am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
FYI original is a bosch s5 or varta silverline, both being identical and made by varta / rebranded for Bosch
Smile
Post #167562 11th Sep 2012 10:48am
Laurie
I agree with blackwolf and Grockle.
OEM ones work out cheaper in the long run.
Post #167565 11th Sep 2012 10:58am
Smile
All the original batteries I have come across (in both Disco 2 and Defender post about 2000) have been Delphi Freedom, 12V 110Ah, CCA 800A, Delphi part number # 19001340, LR part number YGD100860. In Dec 2011 the list price was �136.95 plus vat.
Personally I would (and did) go for a Delphi in preference to a Varta or Bosch, but that is of course a personal preference based on the fact that my Delphi has outperformed any Varta, Bosch, or Exide batteries I have ever owned (I have heard of Exide being fitted as OE as well).
I believe that the Delphi is a lead-calcium battery (not sure about the others).
You might want to take a look at http://www.defender2.net/forum/topic9463.html where this question has been discussed before.
Post #167566 11th Sep 2012 11:20am
Glynparry25
I learn't a lot from a work colleague a few years ago who used to work in an Exide battery factory. There are different 'levels' of batteries which is decided after manufacture.
The best ones are used by themselves and given a (on average) 10 year warranty (They put their name on them).
The ones that don't meet the highest standard then get put into more categories. Theses are then branded as per manufactures with about a 2-5 year warranty and then the ones that are complete cr@p are put in a unbranded pile- theses are sold off in bulk to complete mugs without a warranty...... e.g. the MOD.
To that end- Always buy batteries from the manufacturer it is the way to ensure you get the best product- If it then brakes before the 10 year warranty, you get a new one (with another 10 year warranty)- bonus
Glyn Dog Sheep
Post #167599 11th Sep 2012 2:37pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Costco Bosch S5 with 830 CCA from Costco with instant replacement for five years, no need for receipt and no questions asked.
I use them for twin battery system and I know with Costco's policy I have batteries for five years.
Post #167734 11th Sep 2012 9:07pm
Eduardo
Thanks to all!
Finally I got the Bosch S5 90Ah with a CCA of 1100. Quite similar to the Varta installed.
Only difference were the CCA (900 in the Varta)
So, we will se how much last Mr. Green
Cheers Eduardo
Post #168000 13th Sep 2012 5:51am
