![]() | Home > Td5 > MAF sensor ? |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Smoke dissapeared on cold startup.
All is well ![]() Will Defender 90 XS TD5 (03 Reg) |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
how much are the MAF sensors will good to see all is well.
I believe mine was 75 plus VAT
Fitted new 'Genuine' sensor last night ...... instant cure !
Cheers guys ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 782 ![]() ![]() ![]() |
I didnt realise i had a problem until i read this thread
![]() I hadn't realised that the performance of my 110 had slowly degraded, but reading this thread showed that my engine was showing some of the symtoms that have been mentioned, flat spot when cold etc. Bought a new siemens MAF sensor and i am now enjoying a smoother more powerfull engine ![]() |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Makes you wonder how many TD5 's are running round with the same issue and the owners are not aware believing the performance or lack of it is quite normal
I agree! I reckon i know my 110 pretty well but i suppose if the performance slowly degrades you dont notice ![]() |
Treebeard Member Since: 27 Jun 2012 Location: Forest of Dean Posts: 40 ![]() ![]() ![]() |
My MAF sensor is completely dead (i.e. zero airflow measured) - has been for ages. Below 2000 rpm all is excellent, but it seems to hit a ceiling when it gets to about 2200 prm if any torque is required (will spin up in 2nd & 3rd on the flat, if I can wait that long!).
Are these symptoms that are caused by a dead MAF sensor? The trouble is that I average 33mpg easily, without driving too slowly either. I suppose that I could only connect it up at weekends... |
Yep I'd put money on !
Obviously your MAF is dead, the symptoms you mention are all linked to it. I'd change it immediately. Should only help your fuel consumption as the engine wil be working more efficiently again. 2007 TD5 90 Hard Top |
New VDO MAF fitted - goes like poo off a spade (everything being relative). No longer a ceiling at 2200 rpm. And the nanocom gets sensible airflow readings.
The LR literature states that the MAF output is used for EGR operation - nothing about fuelling. There are many threads on various forums debating what the MAF output is used for. For me, it is now beyond doubt that there is a possibility that the MAF may contribute to fuelling. Very pleased! |
