Home > Puma (Tdci) > Steering Box Leaking
CapeLandy
South Africa
Big Cry Big Cry Big Cry
While driving through the two Kalahari Parks with terrible corrugations, I did notice a very slight knocking in the steering but never bothered complaining as I know the dealer would have sent it back with "no problems found sir".
Now that the steering box is leaking I guess that problem will be solved when they put in a new one. (I assume)
Mine is weeping from the piston cover according to the manual description of the part.
Anyone else get a new steering box because of a leak? Puma 110 - gone
Series III 1973 - going strong
Post #16649 13th Oct 2009 10:48am
Grockle
Re: Steering Box Leaking
Not had to change any steering boxes on our Defenders James 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #16651 13th Oct 2009 11:04am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
My power steering dumped all its fluid one morning.
It turned out to be a hose connection that wasn't tightened. Apart from being a SOAB to reach, once tightened and re-filled I've had no issues.
Check the hoses and joints because it could be that yours is a slow weep. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #16665 13th Oct 2009 4:21pm
CapeLandy
South Africa
Thanks but I did check the pipe ferrules were tight when you first posted the warning some time back. Definate leak from the internals i'm afarid. Sad Puma 110 - gone
Post #16693 14th Oct 2009 5:15am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
I suspect that my steering box is weeping as well: a tell tale drop of clear fluid that sits on the bottom of the casing at the front of the piston. No other noticeable symptoms though.
It is on the list of items as soon as the dealer can fit me in. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #16718 14th Oct 2009 9:31pm
CapeLandy
South Africa
new steering box on order.
LR now admitted they do see the leak Very Happy (first time they said they saw no signs) Puma 110 - gone
Post #17738 3rd Nov 2009 10:55am
