Home > Puma (Tdci) > White smoke? |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi Guys,
Today I found that my 2009 puma started to emit loads of white smoke in the motor way when throttled heavy at speed around 130kmph. Didn't found any DTC codes with scanguage. Anybody who experienced same or any ideas, please post. Many thanks |
2nd Sep 2012 12:52pm |
[quote="CRJ"]Hi
Not that I hope it is the problem - but it could be the head gasket ( I think it is called). Check for bubbles in the coolant or check the oilfillercap for white "grease". Hope it is something else - but the only thing I could think of. Best Regards Christian[/quote] Many thanks for the post Christian. I do not find any bubbles in the coolant and I suppose if there is a gasket leak , water temp should go up. But mine all look fine. This happens when I throttle heavy at high speeds only. Cheers |
2nd Sep 2012 1:05pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
You can get this where coolant leaks externally onto something hot, like the exhaust manifold. Any signs of dried pink deposits in that area?
2nd Sep 2012 1:26pm |
