Home > Puma (Tdci) > White smoke?
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
White smoke?
Hi Guys,
Today I found that my 2009 puma started to emit loads of white smoke in the motor way when throttled heavy at speed around 130kmph. Sad Sad Didn't found any DTC codes with scanguage. Question Question
Anybody who experienced same or any ideas, please post.
Many thanks
Post #165929 2nd Sep 2012 12:52pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Hi
Not that I hope it is the problem - but it could be the head gasket ( I think it is called). Check for bubbles in the coolant or check the oilfillercap for white "grease". Hope it is something else - but the only thing I could think of.
Best Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #165930 2nd Sep 2012 12:58pm
dilukabey
[quote="CRJ"]Hi
Best Regards
Christian[/quote]
Many thanks for the post Christian.
I do not find any bubbles in the coolant and I suppose if there is a gasket leak , water temp should go up. But mine all look fine. This happens when I throttle heavy at high speeds only. Question Question
Cheers Smile
Post #165931 2nd Sep 2012 1:05pm
wslr
You can get this where coolant leaks externally onto something hot, like the exhaust manifold. Any signs of dried pink deposits in that area?
Post #165933 2nd Sep 2012 1:26pm
