Home > Technical > Defender Stance |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
Its always higher on drivers side its normal
29th Aug 2012 1:48pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I would have said level side to side and arse in the air a bit
29th Aug 2012 2:05pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
90s tend to sit more level that 110s. My 110 looks like a hot-rod if it's empty
29th Aug 2012 2:15pm |
Hes looking from the back
29th Aug 2012 2:17pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Should be pretty much level. But if there is a difference the drivers side should be slightly higher.
Glyn |
29th Aug 2012 2:23pm |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
Thanx Just wierd....since the normal camber of RHD roads are to the left I thought it would actualy be the other way around so that the car runs level on a left camber road? I gues it is this way to compensate for driver weight but holy moly....you need to be quite large to level it out. i am 100kg and don't level it out.... |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Don't sweat it as you can't see it when you're driving Steve.
29th Aug 2012 4:26pm |
