Home > Technical > Defender Stance
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Defender Stance
Can some one tell me what the "normal stance" of a RHD Defender should be???
I.e. If the Defender stand level on a level surface should it be completly level looking from the back or should it lean to the one or the other side?
Would like to know before I book her in for service------the dealers wouldn't know in any case and just tell me it is normal Rolling Eyes
Post #165098 29th Aug 2012 1:40pm
ibexman
Its always higher on drivers side its normal Thumbs Up
Post #165100 29th Aug 2012 1:48pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I would have said level side to side and arse in the air a bit
Post #165102 29th Aug 2012 2:05pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
90s tend to sit more level that 110s. My 110 looks like a hot-rod if it's empty
Post #165103 29th Aug 2012 2:15pm
ibexman
Hes looking from the back Rolling Eyes
Post #165104 29th Aug 2012 2:17pm
Glynparry25
Should be pretty much level. But if there is a difference the drivers side should be slightly higher.
Glyn Dog Sheep
Post #165106 29th Aug 2012 2:23pm
Regard
Thanx Thumbs Up
Just wierd....since the normal camber of RHD roads are to the left I thought it would actualy be the other way around so that the car runs level on a left camber road?
I gues it is this way to compensate for driver weight but holy moly....you need to be quite large to level it out. i am 100kg and don't level it out....
Post #165107 29th Aug 2012 2:23pm
Happyoldgit
Don't sweat it as you can't see it when you're driving Wink Steve.
http://forums.lr4x4.com
Post #165125 29th Aug 2012 4:26pm
