Home > Maintenance & Modifications > Chassis stuff |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4627 |
I remember the time when I had lots of long hair and I could rub my fingers through it and get enough grease to coat a Land Rover chassis. Sadly the hair is nowhere near as long or as plentiful so in order to do the chassis it was the time honoured paint and brush.
I invested in four three tonne axle stands but it is still an onerous task lying on your back applying the paint.Sore on your wrist, sore on your back, sore on your neck, in fact just about sore everywhere!This is after jacking up the vehicle four times using the vehicle's hydraulic jack to put the jacks in place and remove the wheels. Putting the wheels back on afterwards is even worse. Lifting and fitting four alloys with 235 tyres in succession is not a task to be undertaken lightly. I forgot to mention that I had two Pumas to do. No nookie in the immediate aftermath as you can imagine First coating was Triflo which is really thick and builds up muscles nicely. After a few days a coating of Dulux gloss was applied - just to add a bit of class. Yep I'm a glutton for punishment. Anyway here's the results. Click image to enlarge Click image to enlarge Here is how it sheds water. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
25th Aug 2012 4:46pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Dulux gloss?!?
25th Aug 2012 4:52pm |
Yep, works wonders as a top coat. Says on the tin that it is good for wood and metal. Did,nt really need it but just put it on as a finishing touch. Can see myself in the chassis! 1982 88" 2.25 diesel
25th Aug 2012 4:56pm |
Forgot to mention also did brackets outriggers etc. 1982 88" 2.25 diesel
25th Aug 2012 4:57pm |
Looks lovely!
Now that you know your way around the chassis you're welcome to do mine! |
25th Aug 2012 4:58pm |
Male or female? 1982 88" 2.25 diesel
25th Aug 2012 5:00pm |
Female and very attractive. Now where's your brush big boy?
25th Aug 2012 5:01pm |
Checking the Ryanair site now 1982 88" 2.25 diesel
25th Aug 2012 5:11pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
Well done Sir Spud
i have long brown hair but mustach , is it ok? www.newfoundland.gr |
27th Aug 2012 8:37am |
27th Aug 2012 7:19pm |
