Home > Maintenance & Modifications > Goodwinch TDS 9.5i v Britpart DB9500i
BigWheels
The 2 I'm currently considering, to fit in a Mantec http://www.mantec.co.uk/images/products/fu...0A-BAr.jpg
The winch in the pic, a Warn, is too expensive for my wallet or self (solo) rescue needs.
Both Goodwinch & Britpart are bridge winches, as the Warn is. Both the former are about the same price.
If there are any other, better, I'd be glad to know. Are any sold by the site's sponsors? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #164319 25th Aug 2012 11:42am
My experience with other people buying cheap winches is, times the cost by two, if it's less than the Warn, save some more and buy the Warn.
When you are stuck, you need something reliable.
Certainly wouldn't buy a Britpart winch, answering your question.
Post #164331 25th Aug 2012 1:46pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
What about Talon series of Superwinch. 100% waterproof, works 1m under water. Superwinch guarante www.newfoundland.gr
Post #164333 25th Aug 2012 2:02pm
bob neville
I've got a Talon 9.5 SR and it is an excellent winch. Used in anger quite a few times now and never had an issue.
The 90 is getting a Goodwinch 9.5TDS, on reputation they are also very good.
I would steer clear of the s*****t winch if it is of the same quality as a lot of their other goods.
You are best spending a bit more money on a better quality winch that you can rely on. No point having a winch stuck on the front if you are not sure it is going to work when you need it.
Andrew at Defenderbits can get you a Goodwinch but don't expect a big discount as the margins are tight on them.
2013 Defender 90 CSW - sold
Post #164335 25th Aug 2012 2:13pm
excossack
I am happy with my 12k Lbs Goodwinch (not a bridge model) and has been used in anger a few times to recovery stuck rally cars from down banks. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #164374 25th Aug 2012 7:35pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Buy a goodwinch tds goldfish from David cheap but a bloody good winch I got rid of warn winches to get the tds winches my front one is built with a bow motor 2 on it
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #164376 25th Aug 2012 7:43pm
jst
i am a strong believer in buy the best and only buy once.
what do you want the winch for? and how often are you going to use it?
Britpart winches in my experience dont seem to last long.
Talon ones looked good when i saw them on display in Croatia but i haven't seen any in use.
Goodwinch - we used one as rear winch for Howlin Wolf for 2 seasons with a Bow2 motor and it never failed. pulled like hell. very cheap very reliable but slow - hence why we ran it on the rear where speed is not a critical but reliability and low down grunt is essential.
Warn - i have 3 x 8274s, all tweaked and all expensive for what they are. main reason for running them is the speed you can get plus the fact spares - go to a comp and all my mates are running them so i can borrow as required. for the tds we never needed spares........
so do you buy a winch from a company that sells loads of products for which they have a not the best reputation or do you buy a winch from a company that specialises in them with an excellent reputation i suppose is the question. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #164377 25th Aug 2012 7:57pm
BigWheels
Visiting Defenderbits web site, they sell the Superwinch LP8500, which incl VAT is cheaper than Goldfish (& Britpart).
My use would be self-recovery, so only occasional. Of course having one I might want to use it more Razz Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #164398 25th Aug 2012 9:35pm
SimonR
Given a choice of any low-line winch, regardless of cost, I would buy (and indeed have) a Tds Goldfish.
It's nicely engineered and never fails. It's the one winch you can guarantee will work when you need it - even if it's sat idle for years.
Si
Post #164407 25th Aug 2012 10:32pm
BigRuss
Now I have neither or any other winch for that fact but have had a look at goodwinch's next to warns and the most noticeable difference is that the chrome on the goodwinch isn't as thick as the warn and started rusting after a couple of months on the front or a vehicle. Russell
2011MY 110 XS USW Black
Post #164474 26th Aug 2012 11:25am
excossack
I replaced my stay bars with some made from stainless bar looks much better than the flaking chromed version, 1999 Defender TD5 110
Regards
John M0VAZ
Post #164475 26th Aug 2012 12:09pm
