Home > Maintenance & Modifications > SVX style rear turn signals from Mobilecentre - now fitted |
Placed the order with Tim from Mobilecentre a few weeks ago and package arrived within 2 days. Two clear LED turnsignals (to replace the standard SVX versions which still remained incandescent bulb fitted), 6 gaskets so that I could also install the gaskets on the standard SVX LED rear/stop lights, rear fog light and reverse light. Land Rover does not bother fitting these gaskets in the factory, it is not a real necessity, but a nice little upgrade, further a new flasher relay to replace the original which is necessary to avoid the flashing frequency to increase due to the LED's having much lower wattage, and 12 stainless steel screws to replace all the original ones. In hindsight must admit that it seems that the OEM ones on my SVX were stainless steel after all, contrary to what was said here on the forum.
The entire replacement was fully plug and play, and a good occasion to get all rear lights off, cleaned behind, extra Dinitrolled, all electrical contacts WD-40'd, etc. The result is perfect, the indicators now when not on have exactly the same appearance as the brake/rear position light, and when the turn signal is on, the LED pattern is an exact match with those brake/rear position lights, and last but not least, the indicator flashes are stronger and with the known crisp on/off typical for LED's. Nice upgrade, and very good service from TIM Here are some pictures of "before 'n' after".......... No, not that one Before Click image to enlarge After Click image to enlarge Before Click image to enlarge After Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 15th Jan 2016 4:49am. Edited 3 times in total |
24th Aug 2012 8:59am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
You can put the indicator in the standard LR position now...
Land Rover only moved the indicator into the inner positions for aesthetics - i.e because the incandescent lamps didn't match the other LED's. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
24th Aug 2012 10:45am |
Thanks Ian, had not thought of that, but was a quicky to sort that one out. Done now as you can see below Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
24th Aug 2012 1:02pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Glad you are happy and sorry about the delay whilst we were at Billing
Tim |
28th Aug 2012 11:50am |
