Home > Puma (Tdci) > Central silencer replacement
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Hi, I am thinking of replacing the central silencer on my 110. I have found several around on the Internet for reasonable prices. my question is: will it be an MOT failure? I mean... I did on my previous 90 back in Italy, but there the MOT is close to a joke, while here in the UK they seem very thorough.
I need your advice guys Smile
Post #163350 20th Aug 2012 8:05pm
Straight through centre silencer no probs with MOT Thumbs Up After all it's making no difference really other than flow it's not like removing the Cat then again even a de-cat is still legal (for now anyway) No Guts, No Glory.
Post #163352 20th Aug 2012 8:10pm
bob neville
Did this on my 2009 110, TF centre pipe replaced centre box.
No problems with the MOT Thumbs Up
2013 Defender 90 CSW - sold
Post #163353 20th Aug 2012 8:11pm
CyberCharlie
Guys I am impressed... 6 minutes to get the answer. Unbelievable Smile
Thanks a lot, i'm buying pipe tomorrow Smile
Post #163360 20th Aug 2012 8:16pm
T1G UP
only issue i can see it that it would be boomy. i've seen a 110 mid box with a small cherry bomb style silencer fitted. Anyone got one on here...might of been alive or twisted?
De cat makes it louder aswell
Post #163369 20th Aug 2012 8:48pm
AndyS
Does removing the mid box really do much while the cat is still in place? Would removing the cat and leaving the mid box be a better thing to do?
Post #163393 21st Aug 2012 6:23am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Removing the cat and leaving only one box made a huge difference to mine.
Post #163400 21st Aug 2012 7:19am
CyberCharlie
No I don't want to remove the cat. I did the modification on my previous Td5 and the performance didn't really change much nor did the fuel efficiency. Just the sound was a little more natural and at high RPM the turbo whistle was a little more audible.
The main reason why I do this is probably that I just feel like spending 80 quid and crawling under my Defender on a sunny Sunday afternoon Smile
Post #163401 21st Aug 2012 7:24am
wslr
It makes a big difference on the Puma though, especially with a remap.
Post #163432 21st Aug 2012 10:15am
CyberCharlie
It is set then... pipe first, remap will be my birthday gift Smile
Post #163435 21st Aug 2012 10:19am
It is worthwhile doing believe me especially on the Puma as said above. I think there is a slight acceleration boost even as standard with no re-map as simply the gasses can exit quicker and more easily and sounds nicer even with the cat in place as mine is. Just hope your bolts on there are fairly new or you'll have some fun with them if their rusty Neutral No Guts, No Glory.
Post #163438 21st Aug 2012 10:38am
CyberCharlie
Thanks Steve Smile
when I did my previous Defender, most nuts were ok, the last one was a nightmare to remove... so I chopped it off Smile
Post #163443 21st Aug 2012 10:50am
No problem. Yes I did have to cut mine off to as they were rusty as well. When you actually look at the silencer it's self you can see just how it is restrictive as the entry and exit are off set and there seems to be some kind of baffle(s) inside obviously to bring the noise level down. It's also heavy and drops down a lot which could be a problem catching on something. All the same mines been melted by now at the local scrap merchants Laughing No Guts, No Glory.
Post #163470 21st Aug 2012 12:18pm
bob neville
Removing the centre box on my 110 has made no difference to the sound level at all and it does not boom.
90's centre box removal does boom and Alive sell the centre box with the cherry bomb for these.
Gary advised I would not need the cherry bomb on the 110 and he was correct Thumbs Up
CC - I had to cut the rear bolts off my mid box when I fitted the centre pipe, there was no way that they were ever coming undone Shocked
Post #163483 21st Aug 2012 1:38pm
wslr
I've got a 3 inch bore 304 stainless turbo back system on my 110 and the noise is best described as pleasurable. Not as nice as Td5 at the low end, but at least as good as under load. It is an XS with some insulation in the back... Laughing
Post #163557 21st Aug 2012 7:41pm
