Home > Puma (Tdci) > Central silencer replacement |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 |
Hi, I am thinking of replacing the central silencer on my 110. I have found several around on the Internet for reasonable prices. my question is: will it be an MOT failure? I mean... I did on my previous 90 back in Italy, but there the MOT is close to a joke, while here in the UK they seem very thorough.
I need your advice guys |
20th Aug 2012 8:05pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Did this on my 2009 110, TF centre pipe replaced centre box.
No problems with the MOT Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
20th Aug 2012 8:11pm |
Guys I am impressed... 6 minutes to get the answer. Unbelievable
Thanks a lot, i'm buying pipe tomorrow |
20th Aug 2012 8:16pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
only issue i can see it that it would be boomy. i've seen a 110 mid box with a small cherry bomb style silencer fitted. Anyone got one on here...might of been alive or twisted?
De cat makes it louder aswell |
20th Aug 2012 8:48pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Does removing the mid box really do much while the cat is still in place? Would removing the cat and leaving the mid box be a better thing to do?
21st Aug 2012 6:23am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Removing the cat and leaving only one box made a huge difference to mine.
21st Aug 2012 7:19am |
No I don't want to remove the cat. I did the modification on my previous Td5 and the performance didn't really change much nor did the fuel efficiency. Just the sound was a little more natural and at high RPM the turbo whistle was a little more audible.
The main reason why I do this is probably that I just feel like spending 80 quid and crawling under my Defender on a sunny Sunday afternoon |
21st Aug 2012 7:24am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
It makes a big difference on the Puma though, especially with a remap.
21st Aug 2012 10:15am |
It is set then... pipe first, remap will be my birthday gift
21st Aug 2012 10:19am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
It is worthwhile doing believe me especially on the Puma as said above. I think there is a slight acceleration boost even as standard with no re-map as simply the gasses can exit quicker and more easily and sounds nicer even with the cat in place as mine is. Just hope your bolts on there are fairly new or you'll have some fun with them if their rusty KEEP CALM AND Drill ON
21st Aug 2012 10:38am |
Thanks Steve
when I did my previous Defender, most nuts were ok, the last one was a nightmare to remove... so I chopped it off |
21st Aug 2012 10:50am |
No problem. Yes I did have to cut mine off to as they were rusty as well. When you actually look at the silencer it's self you can see just how it is restrictive as the entry and exit are off set and there seems to be some kind of baffle(s) inside obviously to bring the noise level down. It's also heavy and drops down a lot which could be a problem catching on something. All the same mines been melted by now at the local scrap merchants KEEP CALM AND Drill ON
21st Aug 2012 12:18pm |
Removing the centre box on my 110 has made no difference to the sound level at all and it does not boom. 90's centre box removal does boom and Alive sell the centre box with the cherry bomb for these. Gary advised I would not need the cherry bomb on the 110 and he was correct CC - I had to cut the rear bolts off my mid box when I fitted the centre pipe, there was no way that they were ever coming undone Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Aug 2012 1:38pm |
I've got a 3 inch bore 304 stainless turbo back system on my 110 and the noise is best described as pleasurable. Not as nice as Td5 at the low end, but at least as good as under load. It is an XS with some insulation in the back...
21st Aug 2012 7:41pm |
