Home > Maintenance & Modifications > Fitting a bed/mattress end to end in a 90 Puma XS?
BigWheels
Puma 90 XS station wagon. No bulkhead, just the bar. I want to convert back to front on the passenger side into a single bed sleeping area (I travel alone). Don't care about removing seats if needed.
Has anyone done this in their 90? If so what did you do? Any suggestions? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #162933 18th Aug 2012 6:07pm
K9F
Unless you're a dwarf or prepared to sleep in the foetal position I would have thought it impractical.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162935 18th Aug 2012 6:12pm
BigWheels
Not just the cargo area, but along the length of the vehicle. Dashboard to rear door. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #162937 18th Aug 2012 6:14pm
K9F
Embarassed Sorry, my mistake but it did conjur up humorous images. Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162939 18th Aug 2012 6:20pm
Surrey Rover
No, but as an alternative to building a frame and removing the passenger seat:
If you don't want a permanent structure and are not loaded to the gunnels, then you can get a fishing bedchair into the back of a 90. You have to fold the front seats as far as they will go towards the dash and then you will get it flat, its very comfy and of course folds up small once your done in the morning. Nick
2.2 110 Tipper
Post #162940 18th Aug 2012 6:29pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Also not a fixed idea either I'm afraid but I attach a hammock to the roll cage on the front left + back right corners.
Obviously this only works if you have a roof rack/roll cage and as said before, not loaded to the top but is very comfy!!
Post #162942 18th Aug 2012 6:41pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
This is a 'short' mate of mine in a series one - there ain't much room......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Euro-Leafing to infinity and beyond.....
Post #163000 18th Aug 2012 10:49pm
have you considered a roof tent ? less messing about with the vehicle and you can sell the tent when you've finished touring
Post #163017 19th Aug 2012 7:43am
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
It can be done...
When I had my Turbo diesel 90 I made a platform out of half inch ply that rested on the dash (with the seats folded down) then on a wooden bar on top of the bulkhead in the middle, and a metal frame at the rear. Cut the ply into 4 pieces with the joint at the bulkhead. This had the flexability of a single or double bed. It also meant I could leave the rear boards in place to hid all the camping gear out of sight, or stack more smaller items up top.
Was cozy and had limited headroom but there was no messing around with wet tents!
Single arrangement
Double bed
Loaded up with just the rear boards in place
 2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
Post #163039 19th Aug 2012 10:57am
Glynparry25
I would go for:
Something like a MSS draw to put between the wheel boxes which will level it all out. Then buy a load of foam to the right thickness for a mattress and cut it to shape and size (for storage/ removal).
As for the front- I would either make the cubby-box quick release or move across to a cubby-tray. This way you can have your legs reaching through to the front and the rest of you in the back.
That is the best 'minimal effort' to set up and pack away every day.
Or...... you could buy a 110 van and just throw a normal 3/4 mattress in the back Thumbs Up
Glyn Dog Sheep
Post #163050 19th Aug 2012 12:27pm
SimonR
Long ago, I had a series 2 SWB and constructed a bed inside along similar lines. I'm 6'7" tall so it really did need to use every bit of space available!
I made it from a stretcher with 2 section telescopic metal poles - intended to fit in a car boot.
One pole was permanently fitted to the rear side panel. The inner tube telescoped out into a receiver bolted to the top of the dash. I had a receiver in the middle of the rear door and one in the middle of the dash which took the other pole. I also made a support for the middle of the 'floating' pole in the middle which jammed against the seat box /rear floor join.
The original stretcher material was about a foot too short - so I cut it into strips which also made it more comfortable.
It was a bit fiddly to set up, but took up no space when stowed. The biggest problem with it was how cold the inside of a Land Rover gets over night, particularly your head or feet - whichever is next to the windscreen!
Eventually I swapped it for a bivi bag and slept under the Land Rover!
Si
Post #163059 19th Aug 2012 1:43pm
spudfan
Ireland
Here is a conversion some one did on a 88" Land Rover
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #163123 19th Aug 2012 7:41pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
" Dormire nel 90 " by Gegio :
http://defendertricks.com/2010/02/22/dormire-nel-90/
Wink Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #163232 20th Aug 2012 10:29am
SimonR
The air bed is a good idea! The support structure pictured for it is a bit OTT - unless you are planning on eating a LOT of pies I suppose?
A steel structure with waffles or sand ladders as the covering would be lighter and more useful (if you needed waffles or ladders).
Using straps to support the feet end is a great idea - cannot fault that!
Si
Post #163244 20th Aug 2012 11:48am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
You might find this useful. http://www.d-90.com/mod/bed2.html
Post #163261 20th Aug 2012 1:32pm
