Home > Puma (Tdci) > 2.2 poor fuel economy
Page 2 of 11 <123 ... 91011>
Doublecabdefender
United Kingdom 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
Hi, I have a 2.2 DCPU XS, to start with the fuel consumption was noticeably higher than my 2.4 (same spec).
Having now covered nearly 10k the engine, gearbox has loosened up somewhat. In fact it is a great drive, I seem to get just under 400 miles per tank, mostly country road and farm driving, with a small percentage of motorways thrown in.
Very happy with the 2.2, however when towing heavy loads I think it's underpowered, but hey I wouldn't have anything else. Very Happy
Simon 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
''I can resist everything except temptation. ''
Post #162304 16th Aug 2012 10:12am
dgardel
Italy
Sorry m8s,
but the EU5 engines eats a little more fuel vs the same EU4 (remember TD5 EU2 vs.EU3?)....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #162316 16th Aug 2012 10:50am
Naks
de-cat and remap Thumbs Up --
Post #162323 16th Aug 2012 11:07am
MartinK
Glynparry25 wrote:
I think you mean DPF for cleaner running (2.4 has a cat). DPF collects the soot which the diesel engine normally throws out the rear- it then burns it off at such a hight temp it turns the soot into ash..... which then just flys out the rear.
Glyn Dog Sheep
Embarassed Yes thanks for spotting my deliberate mistake Embarassed Cool Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #162330 16th Aug 2012 11:30am
K9F
Glynparry25 wrote:
I have sometimes on really good runs got low 30s but average 28-30 (26-28 without Alive map). I don't think anyone else on the forum gets much above 28-32....... Many averaging 26- which means a massive 10mpg down on you. Glyn Dog Sheep
Thumbs Up Agree 100% Thumbs Up
NinetyTD4 wrote:
My 90/2.4 Puma gives me constantly above 450 miles on a tank and I am happy /w it
Shocked Shocked And so you jolly well should be! I too find that figure very hard to swallow! Unless it's constant motorway driving and keeping below 2,500 rpm. The only way I would achieve anywhere near that would be if I pushed it the last 120 or so miles before refuelling. Sure you've done the maths right? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162364 16th Aug 2012 1:33pm
roberty
South Africa 2008 Defender 110 Puma 2.4 SW Alpine White
I have a brand-new MY12 2.2 110 SW in which I recently undertook a 2,000 km trip across South Africa. I dilligently recorded full tank-to-full tank distances and corresponding consumptions for the trip which involved mostly open road cruising but also a week each of Durban and Cape Town city traffic.
Specific fuel consumption worked out at 26.22 mpg / 10.79 lit/100 km. I expected a figure in this ball-park from a new, tight engine and transmission and cruising at 120 km/hr, and it does not strike me as significantly different from my previous MY08 2.4 110 SW. In any event it should improve as the vehicle loosens up. As mentioned elsewhere in this thread, Defenders exported to South Africa are not equipped with DPFs.
I can't say that I notice a difference in the the performance or driveability of the 2.2 vs the 2.4.
However I must admit to the noticeably quieter cabin of the later Defender compared to the 2.4, and the total absence (believe it or not!) of rattles, squeaks and dust- and water-leaks. Remarkably the Defender beats my recently-sold MY11 Toyota Prado VX in the dust-proof department. Long may it last!
Post #162430 16th Aug 2012 6:42pm
AP90
England 2010 Defender 90 Puma 2.4 SW Santorini Black
Hi
I have a 90 2010 2.4 and I can only get 300 miles to a tank and I drive softly doesn't matter if urban, A road or motorway (70mph) 290 to 300 tops engine always seems unwilling and harsh......
Any ideas.........
Thanks
Ash
Post #162449 16th Aug 2012 7:39pm
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
T1G UP wrote:
there Censored ....and my 2.4's worth 5k more than when i bought it Whistle
Honestly? What have you done, spent £15,000 on it or did you steal the 2.4 in the first instance?
Post #162451 16th Aug 2012 7:42pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
this was all said when the 2.4 first came out.
with the 2.2 once the dpf is taken off, it won't be any different to the 2.4.
like this topic is showing, every landy is different, even with the same engine.
Post #162471 16th Aug 2012 8:37pm
rover
I have a 2.2 110 sw, done 2500 miles so far, mix of motorway, a road and country roads, worked out the mpg every fill up and the average is 26.5mpg. Slightly worse then my previous Td5 at 28mpg but I suppose it may get better after a few thousand miles. I would not have the Td5 back though, 2.2 more powerfull, faster, less noisey, far better seating for pasengers, better at cruising at 70 mph better at towing the caravan.
Post #162806 18th Aug 2012 8:18am
noworries4x4
My 2.4 90 would do 300/325 every single tank day in day out, I did get to see 400 a couple of times but this was escorting wide loads at 50mph for hours on end. The new 2.2 is only 250 miles a tank but it has to be said when the light comes on you only put 50 ltrs in where as the 2.4 light on 55 ltrs went in. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #162813 18th Aug 2012 8:44am
DavidITGuru
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Sumatra Black
I've been quie surprised by the poor fuel economy on my 2.2 110. I don't do big mileage so it's not the end of the world but my best / worst / average is only 23 / 18 / 21 which seems a lot thirstier than most. Admittedly the last few tanks (including the 1Cool were hammering along the autoroute at 130km/h but even so...
Am running 255/85/16 KM2s with spacers which probably doesn't help but I wouldn't have thought it makes that much difference.
Post #162827 18th Aug 2012 9:20am
Glynparry25
Speed will make the big difference.
I am running 285s, full cage and about another extra 300kg in protection and recovery gear and still pull back 26-28mpg from my 2.4.
But then again. Before the Defender I had a V8 Discovery returning a constant 20mpg, and before that a Rover Coupe turbo with 320bhp which returned 8mpg when driven hard- Why did I move on- was it because of economy?..... Well, when I drove the Coupe I dreamt of Land Rovers.... so got the Discovery at the right price..... but once I had that I dreamt of Defenders...... and well, now I have it I am over the moon...... it isn't about MPGs it is about that smile you have on your face and the good feeling inside when you see/ drive it. otherwise I would be like all the other douche bags who drive around in mind numbing uncharacteristic Jap/ euro boxes- what a boring way to live your life!!
Glyn Dog Sheep
Post #162831 18th Aug 2012 9:31am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
2010 90 XS. I don't spare the horses and do a combination of country A/B roads , Motorways and minimal city driving with annual touring holidays on the continent. I have completed 26,777 miles
Over 9127 m ( 14689.9 K ) I have used 361.48 gulls ( 1643.32 L ) giving an average of 25.25 mpg ( 11.19L/100K ).
Seeing as my previous vehicle was a Mazda RX8 which rarely got above 20mpg and used £700+ worth of tyres / year and 1L of expensive oil / 2000 miles ( it's designed to do that ) I have become more environmentally friendly. But who cares - I now enjoy every mile I drive. Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #162855 18th Aug 2012 10:13am
DavidITGuru
Well said. The "smiles per gallon" are huge in the Defender. I'd probably still have one if it returned 10mpg!
Post #162867 18th Aug 2012 10:55am
