Home > Technical > Puma Indicator Fuses keeps on blowing
TheWall
South Africa 2008 Defender 110 Puma 2.4 SW Alpine White
Hi,
My Puma's Indicator and shortly after that the hazards fuse keeps on blowing.
Use to be if i drive on corrugated roads but now even city driving i pop fuses.
Anyone had issues like this?
Where was the issue?
Thanks Big Cry http://banddc.blogspot.com/
Post #162642 17th Aug 2012 3:47pm
Grockle
Check for chaffed wires near the bulb holders mate. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #162645 17th Aug 2012 3:52pm
TheWall
i think that has actually been done by a electrician a while ago but typically when it was there everything worked...
Just got it back today after a service and they tried to find the issue but look like no luck.
They checked on all the common places where they usually get shorts on TD5's but could not find anything. http://banddc.blogspot.com/
Post #162648 17th Aug 2012 3:56pm
TheWall
i Have seen the light that tells you you have a trailer hooked come on when the indicators is on... Is that normal? http://banddc.blogspot.com/
Post #162650 17th Aug 2012 3:58pm
Grockle
it should flash once to show the circuit is ok when no trailer is attached. 2.4 90 XS
Post #162652 17th Aug 2012 3:59pm
TheWall
Ok, i will replace some fuses and then check that... http://banddc.blogspot.com/
Post #162653 17th Aug 2012 4:02pm
TheWall
Doe anyone have some kind of blue print of where all the indicator cable's in the defender is? http://banddc.blogspot.com/
Post #162665 17th Aug 2012 5:18pm
K9F
PM sent. May not get back to you if you're not quick until tomorrow. Pub is calling....... Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162667 17th Aug 2012 5:34pm
K9F
E-mails x 3 sent. Hope they are what you require. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162680 17th Aug 2012 6:10pm
TheWall
Hi, Sorry for the late reply. Just got back from a 2 weeks Botswana trip so had a bit of catching up to do at work...
Thanks for the diagrams but that is not quite what im looking for...
I need to check for a short somewhere so was hoping to get a better idea of where in the landy the cables physically are.
Will open up all the indicator lights and check the wiring there but after that...Does the cables go threw the roof, under the seats or where do i need to open...
I guess there is no specific way to test them since it only happens now and then?
THanks http://banddc.blogspot.com/
Post #164087 24th Aug 2012 5:55am
