Home > Technical > Puma Indicator Fuses keeps on blowing |
TheWall Member Since: 08 Jul 2012 Location: Centurion Posts: 23 |
Hi,
My Puma's Indicator and shortly after that the hazards fuse keeps on blowing. Use to be if i drive on corrugated roads but now even city driving i pop fuses. Anyone had issues like this? Where was the issue? Thanks http://banddc.blogspot.com/ |
17th Aug 2012 3:47pm |
i think that has actually been done by a electrician a while ago but typically when it was there everything worked...
Just got it back today after a service and they tried to find the issue but look like no luck. They checked on all the common places where they usually get shorts on TD5's but could not find anything. http://banddc.blogspot.com/ |
17th Aug 2012 3:56pm |
i Have seen the light that tells you you have a trailer hooked come on when the indicators is on... Is that normal? http://banddc.blogspot.com/
17th Aug 2012 3:58pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
it should flash once to show the circuit is ok when no trailer is attached. 2.4 90 XS
17th Aug 2012 3:59pm |
Ok, i will replace some fuses and then check that... http://banddc.blogspot.com/
17th Aug 2012 4:02pm |
Doe anyone have some kind of blue print of where all the indicator cable's in the defender is? http://banddc.blogspot.com/
17th Aug 2012 5:18pm |
PM sent. May not get back to you if you're not quick until tomorrow. Pub is calling....... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Aug 2012 5:34pm |
E-mails x 3 sent. Hope they are what you require. If you go through life with your head in the sand....all people will see is an ar5e!!
17th Aug 2012 6:10pm |
Hi, Sorry for the late reply. Just got back from a 2 weeks Botswana trip so had a bit of catching up to do at work...
Thanks for the diagrams but that is not quite what im looking for... I need to check for a short somewhere so was hoping to get a better idea of where in the landy the cables physically are. Will open up all the indicator lights and check the wiring there but after that...Does the cables go threw the roof, under the seats or where do i need to open... I guess there is no specific way to test them since it only happens now and then? THanks http://banddc.blogspot.com/ |
24th Aug 2012 5:55am |
