![]() | Home > Td5 > Washable airfilters |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
To give more power, they must allow more air through, so more air the more likely there is more dirt getting into your engine.
quentin Member Since: 23 Jul 2012 Location: on tour Posts: 119 ![]() ![]() ![]() |
Stick with the standard filter, Washable filters are rubbish, at least in dusty conditions they are.
You don't need any more airflow unless you had a remap, in which case pull that hiclone thing out of the bottom of your airbox & you instantly get 25-30% more airflow. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
Thanks for the replies chaps.Always worth weighing up the opinions.
What Hiclone thing do you refer to? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Remove the air inlet pipe from the bottom of the airbox [the one from the wing grill to filter housing] .... its a bugga to remove but you need it out of the way,
Then you will feel a restriction in the opening on the airbox. Reach in with pliers, grip the restrictor and yank it out ![]() Looks like a hyclone/ fixedpropeller .. it purpose was to restrict water ingress through the intake , unfortunetely it also restricts air flow. ![]() |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
i have the alive air filter much like a k&n one, really i cant see the difference but it must work k&n is a big name so it cant be false advertising, in the long run its alot cheaper aswell
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Wanna bet ![]() |
i spose
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20599 ![]() ![]() |
Should have gone with an ITG ![]() ⛽️🛢️⚙️🧰💪 |
The Alive filter is an ITG
![]() Having had one in our old TD5 DII, IMHO the problems of oil contamination of MAF's far outweighs the marginal benefits on Land Rover engines. I accept that there may be some performance gains in a free revving petrol or even in a very highly tuned diesel, but for most Land Rover applications you'd be hard pressed to notice any difference. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
check this thread, theres a picture of that hiclone thing that you need to remove. http://www.defender2.net/forum/topic14313....p;start=15 As far as Washable filters, My old 90 hybrid had a 5 litre Ford V8 & to tell you the truth, I put a K&N filter on it & apart from the sticker it made no difference at all. Human nature as it is you spend the $$ on something & the placebo effect comes into play. But frankly I'd stick with the standard element. Even more so because of the comments about the MAF. |
Cheers for the link, I didnt know it was there, I will have a look at the weekend. 1999 Defender TD5 110
