![]() | Home > Puma (Tdci) > New utility - hot feet |
WWA Member Since: 12 Aug 2012 Location: Northumberland Posts: 197 ![]() ![]() ![]() |
Even if your fan is off make sure the heat dial is set to cold.. Even with the fan on 0 if the heat control is set the hot/red, you will get heat coming out of the footwell vents..
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
remember you have a CAT and a DPF now! toasty in the winter though
yes like WWA says, you'll need to turn the heater control to cold/blue otherwise coolant will be pumped through your internal heater radiator
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Yep - I have the same issue. Heater is set to cold and no there's no hot air comming from the footwell vent but instead from around the handbrake and through the seatboxes both sides and through both footwell floors. Over 70 miles an hour it gets ridiculously hot and I need to open the rear side windows to suck the heat out. This does seem crazy to me.
Is this normal? (mine's a 2007 puma 110 SW) Mark |
Sorry cant help with that one! Doesn't sound like it should be normal, does sound crazy. I knew about keeping it to cold/blue but that's as far as my penny's worth goes I'm afraid!!
your sat over the gearbox and transfer box aswell as having a CAT right by your left foot. So yes they do get hot. get it insulated and it'll keep both the heat and the cold away when winter comes....about september at this rate |
Haven't some on here had an issue where some gearboxes had been overfilled at the factory, which made them run hot? Draining and refilling to the correct level seemed to cure it. Darren
Yep - done that a couple of months ago. Gearbox has 2.2L in it and I'm still sitting in a furnace. Mark |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
Had such problem last summer. I insulated gearbox tunnel, seat bases and cubby box floor. Problem solved. Puma 110
What did you use and how easy was it / cost? Mark |
Mark, I used insulating material 8 mm thick with glued base. Don't know what analogs in your country, but here such materials used in car audio. I did it myself so it was very cheap ![]() Seat bases and cubby box floor - very easy! Gear box tunnel was slightly difficult to fit back in place because of increased thickness but it is achievable. Looks like grey material on photo (not mine) but mine was thicker ![]() I think on gear box tunnel and seat bases better to use the same material but 4 mm thick - for better fit ... Puma 110 |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 ![]() ![]() ![]() |
No hot size 12's in my footwells, so it's not a case of "They all do that sir"!
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 ![]() ![]() ![]() |
My 2.2 definitely does this. The other day when I was enjoyr our half day of summer I was tramping on at a fair speed then slowed on side roads and the whole handbrake/transmission tunnel/seatbox area was hot. Happens still. Not nice 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ... 1984 90 soft top with full roll cage, 200 tdi engine etc now sold 2012 USW XS 2.2 "FUU" now gone.... |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
On our recent trip to France one of our girls burned het toes badly due to a very hot rear floor.
Landrover should send out a warning for this! Cheers Q |
