Home > Td5 > 3 amigos appear and stereo cuts...
oysbjerk
Norway 2002 Defender 110 Td5 DCPU Sumatra Black
My 02 Defender Td5 DCPU is not feelin well. Once in a while (2-3 times a day lately) the warning light for TC,ABS & PB lights up in the dash. At the same time the stereo cuts ( resets as when the battery is disconnected..) the stereo comes back, with power that is, after appx 15sec. The warning lights remain.
I've had a look on similar threads here, but can't say I've seen anyone mention the stereo bit...
Anyway, any thoughts on this subject is greatly appreciated Smile
Øystein
Post #160806 8th Aug 2012 6:24pm
You really need to find out what the fault recorded with the three amigos is to get a better idea of what's happening. The most common cause of the amigos is a faulty wheel speed sensor or faulty harness from the sensor to the ECU, but I have never heard of this having any effect on the stereo!
When you reset the lights, what error code(s) were recorded?
Post #160915 9th Aug 2012 9:46am
oysbjerk
I have not had the error codes read yet. If I turn off the ignition and restart the warning lights are off and back to normal.
Post #160916 9th Aug 2012 9:50am
Glynparry25
Sounds simmilar to what I had....... does it happen when going over bumps or uneven ground?
If so, check all the earth cables- Battery, Chassis (next to battery box and looks like a p-clip) and then on the transfer box.
Regards,
Glyn Dog Sheep
Post #160927 9th Aug 2012 10:43am
oysbjerk
Good news.
Got the fault codes read....loss of power to ABS...and various other functions... Turned out that one of the screws on the 100A fuse link under the RH seat was loose Smile After tightening it everything is simply perfect Smile A stupid thing, but good news Smile)
Thanks for the help guys. Bow down
Post #162967 18th Aug 2012 8:01pm
Glynparry25
Thumbs Up Thumbs Up Thumbs Up Awesome news.... so a happy Defender driver again Thumbs Up Thumbs Up Thumbs Up
Glyn Dog Sheep
Post #162981 18th Aug 2012 9:26pm
