Home > Puma (Tdci) > Leak from gearbox?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Leak from gearbox?
Hi all,
I popped under the 110 to investigate a rumbling sound at low revs. It sounded like something loose; in the end I couldn't find it - however I saw what looked like a leak, just curious if anyone ever saw this before:
Post #160142 5th Aug 2012 4:52pm
An oil leak on a Land Rover? Yes, I've seen one or two of those before Rolling with laughter
If I'm reading your pictures correctly, it looks like the rear output seal on the transfer box. Not wholly uncommon but also not too difficult to fix either. Darren
Post #160148 5th Aug 2012 5:22pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
It,s just Land Rovers way of letting you know it,s not empty yet. 2005 Td5 90 XS
Steve
Post #160164 5th Aug 2012 5:57pm
dgardel
Italy
If a land rover leak oil means there is oil inside.......
serious mode ON
there is a recall (P022 thanks to rasmussen) for te oil leak from the rear shaft (oil on brake drum) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160202 5th Aug 2012 7:38pm
eutek
Thanks guys - I figured I was asking for it by posting a query re. oil leaks and Defenders! Laughing
Is there any way to check if a particular vehicle has had the requisite recalls carried out?
Would vehicles that are out-of-warranty be covered?
I'm curious if the fact that I'm parking on a rather steep incline for the past two months has anything to do with this?
Post #160302 6th Aug 2012 1:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Register on Topix (it's free) http://topix.landrover.jlrext.com/topix/vehicle/lookupForm , and enter your VIN number. Will tell you if there are any outstanding recalls. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #160359 6th Aug 2012 6:56pm
rasmussen
France
Sorry to intervene,
I have registered on Topix and when I type in my car's vin I can see:
Outstanding Campaigns:
P022 - PARK BRAKE OIL CONTAMINATION
This means that the seal has not been change by Land rover dealer so far?
Can I also read from this that clutch issue has been solved earlier on my particular car?
I have only had the car for less than 4 month and I don’t know if the clutch has been changed or not?
Cheers,
Post #160742 8th Aug 2012 11:34am
familymad
Great recommendation - mine says the recall to fit the 3.2TDCi has not yet been completed under warranty? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #160757 8th Aug 2012 1:43pm
WelshGas
Hi Rasmussen, As far as I am aware there was no product recall regarding the clutch, as not everyone had this problem. The P022 recall should be carried out by you local dealer even if your vehicle is out of warranty. Bow down LANDYWATCH
Post #160823 8th Aug 2012 7:12pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I am sure this is a full safety recall and that LR will do this FOC even outside of warranty period
Post #160833 8th Aug 2012 7:55pm
