![]() | Home > Wheels & Tyres > Tyre Repair in France |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
having had a few punctures in my time a tyre guy once explained that it depends on the size of the hole. Smallish punctures get a plug, larger ones get a patch (or so I was lead to believe)
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
That might make sense as it did look like Frankenstein's neck bolt that lodged itself in my tyre! Still a bit concerned though as it's left quite a big hole in the middle of my tread.
Lazy gits didn't even rebalance my wheel even though I asked them to - they just marked the valve position on the tyre and refitted it aligning the mark. |
Any tyre experts out there that can shed some more light on this?
Thanks, Mark |
Not a tyre expert.
Have had chalk valve position trick done before. Never experierenced any problems afterwards. You could always carry a sticky string kit with you. Hardest problem is finding the puncture. OK sticky string is not road legal Brendan |
Hey Brendan, No amount of sticky string would have fixed this one - the head of the bolt sticking out the tyre would have needed a 19mm spanner! Mark |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
The Land Rover Working in the Wild handbook states...
"Emergency puncture repairs can be carried out without patches or replacement tubes by stuffing tyres with rags or grass.Tyres must be discarded after use in this way" (It does not mention anything about rebalancing the wheel after stuffing it with rags or grass ![]() Judging by that, your patch repair seems like overkill! ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
