Home > Technical > parking brake lurch
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
parking brake lurch
Hi all.
Has anyone made or bought a hand brake that works on both rear wheels rather than the prop, thus removing the lurch as the trans backlash is taken up?
I was thinking initially to have a hydraulic and cable caliper like on astras but then thought about a complete stand alone cable caliper on a new bracket. The other advantage being they could be set as fiddle brakes too to aid traction in extreme terrain.
Any thoughts? Rhubarb and custard let fly with their secret weapon.
Post #159333 2nd Aug 2012 5:27am
jst
for fiddles to work they need to be hydraulic really, which isin't ideal for MOT on a park brake.
i am not aware of any park brakes for rear discs on def. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #159335 2nd Aug 2012 5:55am
After replacing an electronic park brake on a Disco 3, I hope they never appear on a defender !!!
Post #159338 2nd Aug 2012 6:40am
lambert.the.farmer
So its a matter of being creative then. Rhubarb and custard let fly with their secret weapon.
Post #159341 2nd Aug 2012 7:13am
You could fit a hydraulic valve on the brake circuit so that the existing footbrake retains its pressure (similar to the MECH LOCK, see http://www.mudstuff.co.uk/Meck_Lock.shtml).
This will apply the brake on all four wheels. Keep the standard handbrake as well.
I have to admit that I am not entirely clear what the issue is with the standard handbrake though, since with the right technique it is possible to avoid any run-back anyway (just keep the slack tight on the transmission by using the clutch as you apply the handbrake).
Post #159359 2nd Aug 2012 8:58am
lambert.the.farmer
The issue comes with hitching the big trailers. Will look into a line lock. Rhubarb and custard let fly with their secret weapon.
Post #159464 2nd Aug 2012 3:24pm
farmer giles
what about the x-eng handbrake conversion? (admittedly i don't know how it works) Embarassed
Post #159477 2nd Aug 2012 4:07pm
lambert.the.farmer
Whilst they are far more efficient than the factory drum they are still a transmission brake and they still lurch as the trans slack is taken up. Rhubarb and custard let fly with their secret weapon.
Post #159487 2nd Aug 2012 4:34pm
