![]() | Home > Technical > parking brake lurch |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Hi all.
Has anyone made or bought a hand brake that works on both rear wheels rather than the prop, thus removing the lurch as the trans backlash is taken up? I was thinking initially to have a hydraulic and cable caliper like on astras but then thought about a complete stand alone cable caliper on a new bracket. The other advantage being they could be set as fiddle brakes too to aid traction in extreme terrain. Any thoughts? Rhubarb and custard let fly with their secret weapon. |
After replacing an electronic park brake on a Disco 3, I hope they never appear on a defender !!!
So its a matter of being creative then. Rhubarb and custard let fly with their secret weapon.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
You could fit a hydraulic valve on the brake circuit so that the existing footbrake retains its pressure (similar to the MECH LOCK, see http://www.mudstuff.co.uk/Meck_Lock.shtml).
This will apply the brake on all four wheels. Keep the standard handbrake as well. I have to admit that I am not entirely clear what the issue is with the standard handbrake though, since with the right technique it is possible to avoid any run-back anyway (just keep the slack tight on the transmission by using the clutch as you apply the handbrake). |
The issue comes with hitching the big trailers. Will look into a line lock. Rhubarb and custard let fly with their secret weapon.
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
what about the x-eng handbrake conversion? (admittedly i don't know how it works)
Whilst they are far more efficient than the factory drum they are still a transmission brake and they still lurch as the trans slack is taken up. Rhubarb and custard let fly with their secret weapon.
