Home > Puma (Tdci) > Just bought a 2.2 110CSW to replace my 2.4 |
richardd Member Since: 01 Aug 2012 Location: Glasgow, sort of Posts: 21 |
scrub the turning circle question - found the thread about the stops. I should have known that without asking
1st Aug 2012 9:50am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
hi richard,
can you mount the cubby box further back on the security box so that the raked front of the cubby box gives better access to the gear stick? |
1st Aug 2012 9:53am |
As yo can see from this pic, the box is extremely well designed but it is just far too hight even though I have mud stuff seat rails as well. TBH the box gets in the way of steering and although I need the security box for carrying funky drugs and stuff it does not need to so big that a family of Albanians could live there. |
1st Aug 2012 10:03am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
I thought they were meant to mount set into the floor ? They must have thought of the problem you have, I'm sure Bren will be along shortly to explain
1st Aug 2012 11:10am |
shouldn't you take the timber rails off the cubby box before fitting it to the security box?
front runner do a security box half that depth but with no electrical plug in points. Send a pm to Greeni on this site as i believe he deals with front runner |
1st Aug 2012 11:22am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Richard
Had the same problem when fitting an MSS cubby box. I drilled the box to move the mount holes forward in the box a couple of inches - had the effect of moving the box back. The box does overhang the rear footwell a bit but does not cause an issue. At least I can use all the gears now and the l/h range lever ! Could you relocate the holes in the under cubby box in a similar way ? Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
1st Aug 2012 11:27am |
No, they are designed perfectly to fit on the inspection plate as long as you put in a couple of new riv nuts!
1st Aug 2012 12:44pm |
Perhaps they are not designed to have a cubby box on top then ?
1st Aug 2012 12:47pm |
I thought about that but then the cubby box top isn't level. The frontrunner one doesn't have the electric points which was the starting point! |
1st Aug 2012 12:50pm |
Have you asked Brendan how this problem is solved ?
1st Aug 2012 12:51pm |
Which problem? The height issue is a purely subjective one (ie it is too tall for my needs) and I'm going to look at adjusting it. It's not a product quality issue. |
1st Aug 2012 1:02pm |
Ahhh, sorry, I presumed the problem was one of design - it's too tall ?
1st Aug 2012 1:06pm |
for my taste and use, yes.
My plan is to remove the lid and hinge assembly (6 bolts) cut off the top half, bend in the sides to re-create the box and then weld back the the lock catch plate and repaint. A pleasant evening's dicking around with metal, grinders and my TIG welder but I've got my demountable towbar, front spots rear bumperettes to fit first |
1st Aug 2012 1:14pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
why not mod the cubby box? alot easier
1st Aug 2012 5:47pm |
