Home > My Defender > My new project 90 2.2 arrives today for its new heart.
Page 3 of 8 <12345678>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
come on man so your telling my intercooler is no good your adding pounds to my budget lol
looking good pete now where the keys Whistle
mine and your at the show will look liek brothers just mine been on steroids lol plus without the engine yet
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #158147 26th Jul 2012 7:55pm
bell-auto-services
Hehe, I hope it will be running next week, I had to order another but brand new this time engine and gearbox today as im still waiting for my original order from a different place to arrive Sad .
Tomorrow I hope to have it arrive all brand new and sparkly Smile
Pete
Last edited by bell-auto-services on 29th Jul 2012 7:26pm. Edited 2 times in total
Post #158148 26th Jul 2012 7:57pm
big steve
well if thats the case pete you know where i am hint hint Whistle
if its up for grabs
Post #158150 26th Jul 2012 7:59pm
excossack
Does or will the curves and length of the air intake pipe from the wing slow down the speed of the air entering the filter? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #158154 26th Jul 2012 8:10pm
big steve
i doubt it mine is currently running through a pipe from the snorkel which will incur a ram type affect but i may be wrong
the other good thing about that filter is you dont have to modyfy the original filter box
Post #158155 26th Jul 2012 8:13pm
T1G UP
bell-auto-services wrote:
While the engine is out ive installed a hi flow BMC carbon fiber air intake system that will go from the new BMC wing mount kit to the turbo when finished, all via a BMC kit made for the 2.4 TDCI which is far larger than the standard intake.
Its all tucked away under the wing baring its outlet as you can seein the picture.
Pete
that would looka lot better knocked up out of ali Whistle
Post #158157 26th Jul 2012 8:14pm
dgardel
Italy
Aha Smile The fishing bait was taken hehe, I was waiting for omeone to ask that question Smile The main difference is in the picture below on the in and out pipes, but it does have some other more secret changes Smile
You know my past, diesel engine have no secrets for me Evil or Very Mad Evil or Very Mad Evil or Very Mad
If I could stay 1 week in the workshop with you I could give a lot to your work..... Whistle Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158161 26th Jul 2012 8:22pm
dgardel
Italy
Or 1 week with the Denso Fomoco devopment unit........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158162 26th Jul 2012 8:24pm
big steve
you wana get that chassis waxoiled as well pete before it starts rusting 2015 2.2 tdci hardtop xs
Post #158163 26th Jul 2012 8:24pm
dgardel
Italy
One Prize competition:
Why the inlet valves are bigger than exhust?
A hint, do not think about pressure effects or pump effects, think about a "wall"...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158166 26th Jul 2012 8:30pm
big steve
more air can be pushed in from the turbo plus the piston is pushing the gasses out
im probly so wrong lol
Post #158168 26th Jul 2012 8:34pm
dgardel
Italy
Pete, will be interesting to measure the max air flow used by the 3.2...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158169 26th Jul 2012 8:34pm
dgardel
Italy
steve
And for a non turbo engine?
It seems a logical answer but it is not correct ....
Again .....
Pume engine head zoom in
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158170 26th Jul 2012 8:37pm
bell-auto-services
Inlets are generally bigger partly because the inlet charge pressure going into the cylinder is lower than the exhaust outlet pressure, though many combinations of valve size ratio are used from manafacturer to manafacturer.
It also gives the engine manafacturer more choice of valve seat design that they may require depending on application and the valve size chosen.
Post #158181 26th Jul 2012 9:16pm
bell-auto-services
I hope to measure it unrestricted somehow, not worked out how exactley yet though lol. I may do some vac pressure tests on the current inlet setup and see if i can make it as free as possibile.
Post #158187 26th Jul 2012 9:29pm
