Home > Technical > Electric window |
Right Karlos,
Fuse 15.... 5amps is the supply fuse to BOTH front windows..... This supply is fed through two independant fuses for the front windows FUSE 34....20 amp for the driver's side... FUSE 35....20 amp for the passenger's.... Each fuse supply then goes through their respective up/down selector switches to the motors.... Check the fuses first, if no go swap the switches over to see if the fault transfers. If still no go would suspect an open circuit in the door umbillical (coloured wires red, blue and black (earth)) but you would need a multimeter to confirm the latter. *EDIT* Again....There are other fuses in the system but as it is only happening on one side these can be discounted at this stage. Good luck Buddy.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 19th Jul 2012 2:21pm. Edited 3 times in total |
19th Jul 2012 2:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20279 |
Once again astounding electrical advice from Mal. I wouldn't mind betting it's a switch but we'll see. I have never taken the door card off so never seen the set up behind there? Would be interesting to see. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
19th Jul 2012 2:18pm |
Why would a 5 Amp fuse feed to 20 Amp ones? Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
19th Jul 2012 2:22pm |
Kona,
Easy to take the door card off...Not so easy getting the inner plastic sheet off in one piece as they use a bead of the stickiest, gooiest I've ever come acroos to stick it. Like black chewing gum it is. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Jul 2012 2:28pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
Removed, missed my moment !!!!
Trying to keep it simple. Supply relay fuse...same set up you should have if you fit auxilliary lights. Ignition supplies relay 5 amp fuse, pulls in relay, contacts of relay supply through 20 amp fuses window motors. In this case 3 amp feeds 20/25 amp... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 19th Jul 2012 2:41pm. Edited 2 times in total |
19th Jul 2012 2:29pm |
I know the stuff you mean Mal probably great for holding the water in too if any works it's way in there ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
19th Jul 2012 2:30pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Nice one Mal, will have a look 2moz NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
19th Jul 2012 3:01pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4636 |
Talking to someone who drives a VW van. He said that if it rains and he has a window down he is unable to get the window to go up again. This is due to where the switch is placed on the trim. If it gets wet at all the connections are knackeded. He had to remove the switch one evening and dry it with a hairdryer then refit it to get the window to go up. Seems that replacement switches are a big part of the warranty work.This came to light when we found out that our next lot of vans at work will be VW. 1982 88" 2.25 diesel
19th Jul 2012 4:12pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I've got some pics somewhere and will attempt to find them but believe me the inside of the door isn't very exciting... .....of course it depends on what sort of thing turns you on Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
19th Jul 2012 5:46pm |
Karlos,
Any update? Hope it turned out to be something simple.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Jul 2012 4:28pm |
Mal, just checked the 2 fuses that are together and both ok will look for the 5 amp 2moz mate...its getting hot in there without aircon and only 1 window... can't even smoke NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Jul 2012 5:42pm |
I feel so sorry for you ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
20th Jul 2012 5:48pm |
Karlos,
The 5 amp one is ok if the other window is working. Swap the switches over next.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Jul 2012 5:51pm |
