Home > Maintenance & Modifications > Check your hubs !!
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Check your hubs !!
Bored today .. work very quiet, so decided to do a job i've put off for a few months, pop the hubs off and regrease the wheel bearings.
Well ... first thing plainly obvious is LR certainly don't overdo it with the grease on assembly! Probably only 'just' enough in each hub to do an adequate job Evil or Very Mad
More of a worry was the red rust in both rear hubs!! Shocked No sign of water present [now] but obviously been weeping in there from time to time. A better packing with grease would go a long way to prevent this.
I changed all bearing just in case [although they cleaned up reasonably well] and packed all 4 hubs with as much grease as fitted Cool ....and this on a 5 year old motor with less than 20k on the clock.
Well worth checking your's guys if you are able, prevent a forthcoming breakdown just waiting to strike ... Guns and Landrovers .... anything else is irrelevant.
Post #156558 18th Jul 2012 7:23pm
You should check the splines on the end of the halfshafts (and CV's) into the drive hubs whilst you're in there... lack of grease = lots of wear and backlash.
Post #156566 18th Jul 2012 7:43pm
Dave-H
Yea did the shafts .. not CVJ's though ... Guns and Landrovers .... anything else is irrelevant.
Post #156569 18th Jul 2012 7:46pm
Fifth Horseman
Not uncommon, this was mine when I checked it - had been getting a click (clonk) from the rear when starting to reverse Shocked
That was the better one...
Post #156623 18th Jul 2012 9:58pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
BANG....oh dear lost traction.....Gearbox gone or broke a diff., splines gone on shaft, always check them 1st Putting Dreams on Drives at JLR Solihull..
Post #156786 19th Jul 2012 5:58pm
jst
i know its a different kettle of fish, but the Ashcroft axles have two drive member bolts that you removed to replenish the grease in the bearings in situ. pump it in through the top one until it comes out clean from the bottom hole.
CVs are also greasable in situ by pumping the grease up the CV shaft which is threaded to take a grease nipple. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #157095 20th Jul 2012 9:30pm
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
I've found exactly the same on our Puma, Zero grease on the rear drive splines so they've corroded and the mess fortunately didn't get to the bearing (well not that I could see) but it probably had a detrimental effect.
I had about a 5th of a turn of slack in the rear prop. Cue new flanges and halfshaft and it's a lot better.
All for 0.1p of copper slip at the factory! 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #157562 23rd Jul 2012 9:08pm
df1
I know it's an old topic but just wondering does anyone know off hand what size socket is needed to open the wheel bearing nuts on the rear axle ?
It's just I had a look a couple of weeks ago and had no socket to suit, I measured the nut with the calipers to order a socket but have forgotten the measurement.
Post #221476 23rd Mar 2013 7:45pm
Dave-H
52 mm Smile Guns and Landrovers .... anything else is irrelevant.
Post #221482 23rd Mar 2013 7:57pm
df1
Cheers, I knew it was some odd size alright.
Is it the same for the front too ?
Post #221484 23rd Mar 2013 8:08pm
Yup.
Post #221488 23rd Mar 2013 8:26pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Resurrecting an old thread... I have been getting a clunk/click when I engage reverse or downshift into 2nd/1st, when seems to be emanating from the rear of the 110... Also a squeaking sound from one of the front wheels - last time had anything similar it was on the wife's car, and the bearing ended up going at 80mph on the motorway.
Is there a how-to for regreasing the bearings? WOuld what is in the Haynes manual suffice (written in the pre-Puma days, I know - thinking maybe the Td5 has the same layout?)
Post #260774 23rd Aug 2013 8:26am
geobloke
Unnecessary quote removed
I use this method of greasing bearings, works a treat and is dead easy - http://www.youtube.com/watch?v=BhL1uAp_WCw
Not a bad Land Rover specific How To - http://www.youtube.com/watch?v=O4A9MTOOC60
And another - http://www.youtube.com/watch?v=4_5vmZFrvd8
A written article - http://www.repairmylandrover.co.uk/defende...l-bearings
Post #260800 23rd Aug 2013 11:15am
eutek
Thanks for the helpful links, I appreciate it! 😄
Post #261813 28th Aug 2013 7:03am
