![]() | Home > Maintenance & Modifications > Simbars |
Here ya go, in my opinion, the best
![]() http://www.pendle-bike.co.uk/shopping/Whee...e-Rack.php |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 ![]() ![]() |
Do you think the that carrier would still work with the extra distance the spare wheel is held out due to the Mantec wheel carrier, it looks like it is very close to the limit on the website picture without that extra distance. 2.2 2012 110 utility Orkney Grey
Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
If you've got a Mantec wheel carrier, can you not just use a wheel mounted one? The often dire warnings about using these relate to the rear door hinges, but that wouldn't apply in your case. Darren
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
following a simular question before on the forum I followed Greeni's advice and brought a Pendle 4 bike rack off e/bay for £100 and cut it down to 3 bikes (it was like new) It is a great bit of kit and perfect for the task in every way except but does mean you cant open the rear door when bikes are on. DEFENDER 90 TDCI XS,
Do you think the 3 bike carrier would fit, you said you used a 4 bike one of ebay and cut it down. I tend to think the spare wheel would encroach on the first bike position on a 3 bike carrier, that is what I have at the moment with a Thule unit and my one doesn't take the extension adapter. By the way to find one for £100 of fleebay was a bit of a result. 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
